Charging Fault
Sorry if this has already been discussed. Got in my '16 V6S last week. Car started fine, pulled out of the parking spot down my parking garage. All of a sudden the A/C switched off, vents retracted, nav screen went black, stereo turned off. It came on about 1/2 mile later, but then did it all over again. About the 5th time it did it I drove straight to the dealer. They did a hard reset, but it is still doing it. Does it about once a day now. The car starts fine and runs fine.
Today I got in the car and it said 'Charging Fault'. It is going into service on Saturday for the fuel filler neck and they are going to look at it.
Anyone had this issue? Ideas?
Thanks!!
Thanks!!
Thanks!!
Thanks!!
Thanks!!
Thanks!!
Thanks in advance,
Brian
This is not an acceptable outcome. In summary, the work order says that they jiggled the wires around sufficiently so that bumpy roads (at least for now) don't cause a problem. There is still exposed wiring somewhere and this gremlin will reappear at some point.
Sounds like there is cut insulation. Perhaps a wire was shorting to ground. The diagnosis is thorough, but "Moved it away" is not really a repair (as Unhingd said). The cut in the insulation should be found and covered with tape, and inspected to see if other neighboring wires were also affected. Rerouting may indeed make this problem go away forever, or it may not.
