Charging System Fault
Old 05-26-2019, 09:31 PM
Luc Lapierre's Avatar
Originally Posted by Anas Akram
How long was your car in the shop for replacing the alternator?
Mine only took a few hours of actual shop time, according to the invoice. This included looking at a few fiddly things that I had asked about.
Old 07-08-2019, 11:28 AM
malbec's Avatar
Have just had the Charging System Fault message after 19k miles.
As suspected above, the dealer has found that there is an oil seal leak above the alternator.
Also a wire in the system needs replacing.
Car is under warranty.
Old 07-08-2019, 11:48 AM
I'd like to know if there's an effective permanent solution for this.
Old 07-15-2019, 12:43 PM
malbec's Avatar
Just got the car back from the dealer.
It was the gasket on a timing chain cover.
Old 11-04-2019, 10:27 PM
afterburner1's Avatar
jaguar's do not leak oil; it is controlled seepage!
Old 09-01-2021, 12:59 PM
hencorp's Avatar
I'm a little worried - I get "charging system fault" but only intermittent. I shut it off then start it again and its gone and the car runs fine. Not under warranty so wondering the cost of the alternator repair.....anyone know? (2014 f type S, amethyst black)
Old 09-01-2021, 01:25 PM
scm's Avatar
scm
scm is offline
Received 1,460 Likes on 1,105 Posts
If it's intermittent, I'd check the electrical connections in case it's a simple fix.
  #28
Old 09-01-2021, 02:51 PM
DJS's Avatar
DJS
DJS is offline
Received 2,106 Likes on 1,406 Posts
Wouldn’t hurt to fully charge the battery or put in on a tender. Could ward off other issues if it’s a real fault. Might even fix it.
I’m assuming you’re not still using the original battery? If you are, it’s due.
Old 09-02-2021, 03:18 PM
ScagJagr's Avatar
I’m now having the same issue myself. However, while I’m driving the A/C and radio will randomly shut off and then come back on and then off again for 10 minutes. I’ve swapped out the rear battery for a lithium and still can’t figure it out. I get the charging system fault code every third or fourth time I start the car.
EKinSC
XF (X260)
28
10-16-2021 10:38 AM
garyp58
09-03-2021 06:49 PM
Jody Harms
11-09-2020 08:00 PM
antdavis1911
11-04-2019 11:01 PM
nigelmay
11-22-2013 10:26 AM
Quick Reply: Charging System Fault
