Check engine light after reading ECU
I used the ECU tablet provided by VelocityAp to read my ECU file. While reading the ECU the car cycled through all the error code. Once the scan of ECU was complete the car returned to normal but now the check engine light is on. How can I clear the check engine light?
The VelocityAP tool can read/clear codes. No need to buy anything. Occasionally you do need to disconnect the battery for about 5 minutes to reset the vehicle's memory counts as well. Pretty typical, the F Type doesn't like when you use the OBD port haha
dwmilton (05-30-2020)
Both great points. I forgot that that the device could read and clear code. And if an OBD tap-in can mess with the energy control module, maybe it could with others as well. When disconnecting the battery, I've found that counting slowly to 10 is enough.
The check engine light following the read and after installing the new file is common. It will disappear after 5 starts. It leaves one code that is associated with the ECU read... something like "miscommunication with ECU".
I am not sure why you are getting the service required message. I would follow unhingd and stohlens advice and try clearing the code to see if that also clears the service required message. Then try the battery reset.
RGPV6S (12-10-2016)
Received 2,266 Likes
A 'check engine' light is not the same thing as a 'service required' message. Your car is telling you it's time for an oil change or similar.
The service interval clock starts when they perform the PDI. How long did your car sit @ the dealer prior to you buying it?
