check engine light, gas cap issue
So the other week my "check gas cap" light came on. I went and readjusted the cap, came back in the car, started and it went away. Then during the next start up a day later, the check engine light came on. I freaked, called the dealer, took it in. They hooked it up and it was just the gas cap. They cleared the warning light and all was good for a week. Then the other day, the check engine light came on again, also saw a "service required" warning come up. I already had my annual service-inspection january 2016. I have been fiddling with the gas cap here and there, starting the car, driving it like usual for the past 2 days and the check engine light is still there.
Talking to the service guy and and other car guys, seems like the light may take awhile to finally go off, but my problem was how come its doing it so frequently. I feel like even if the light goes off, it'll only be a matter of days before it comes back on. I'll give it another week. Then I'll call the dealer. Is it something they can just replace easily? How common is this? Just frustrating because the car has been great otherwise. Thanks!
You've got the cap tight before you start it, correct? If the gas cap has a poor seal, it will intermittently fail with a DTC (Diag trouble code). Once the dealer clears it with the laptop, it should not return. If the same code does comes back, than the underlying issue hasn't been addressed. If it's not the cap, there could also be a small leak elsewhere in the system. It's not too great of a cause for concern but certainly something to have addressed.
Hope that helps,
Ryan
Hope that helps,
Ryan
Hope that helps,
Ryan
Hope that helps,
Ryan
Received 2,263 Likes
Yes there was actually a warning in the center thingy where it sometimes flashes service required when it becomes due. I was surprised it had a warning like that but was really thankful for it too.
russmdva2000 (05-21-2020)
Thanks, this is very valuable feedback. I'll be sure to bring it up to the service guy. As of now, the check engine light is still on!! Very annoying
When the light comes on, is the gas cap looser than it was? The reason that I ask is that my S2000 is having a similar issue. I tighten the gas cap after filling, but the check engine light will usually come on before I fill again. Every time it's because the gas cap has loosened itself. Obviously the most obvious solution for me is to replace the gas cap and see if the problem goes away. If your gas cap is loosening, I'd suggest the same. Heck, even if your gas cap is not loosening, I'd suggest the same (though it would be less likely to fix the issue).
welp here's the verdict. They replaced the gas cap and now just crossing fingers. I attached the service summary here in case anyone was interested or helps anyone in the future with a similar problem. Hopefully this ends the issue....but for some reason I'm not convinced quite yet.
This may no longer be true, but it was widely published at one point that the #1 cause of check engine lights (CELs) was gas caps not on tight or faulty.
