Classic Additions Indoor Cover
I had Classic Additions make a indoor cover for my Coupe. I asked for some custom piping work, I think it turned out well. I was so tempted to ask for a Union Jack cover they had made for another Jag. I decided to stick with the minimalist look It was cheaper than the Jaguar F-Type cover too!
SNG Barratt USA (06-30-2014)
I think they can do that. I believe the standard logo they use is the JAGUAR text logo. I didnt think about asking for the R logo, that wouldve been cool.
In the past I used the Porsche Smooth-fitting indoor car cover on my Black Turbo S. Then after a few uses I started noticing small straight scratches in the paint. (Easy to see on a black car) After discussing with a detailing buddy about it he highly recommended I stop using it unless I had just washed the car.
So I really do not use it that much since I don't store the car in the winter.
Just something to think about. As you put it on and off the car you are quite possibly inducing small scratches as you push or pull dirt or other particles across the paint.
Walt
Walt
This is why I haven't considered getting a cover. Grit sticks to the inside of the cover, and it's really difficult to avoid abrasion while stretching the cover over the car. Even a single particle of grit can create a long scratch on the car when slid over the hood.
I use it to keep it clean longer after a wash. Even with the garage doors closed, I get tons of tree pollen which tends to stick to the wax more than dust. Accumulation of dust and pollen is a big reason I got one that is very light weight and washable. For those that do use one, I recommend folding it lengthwise while on the car, then rolling it up and off rather than dragging it. Makes it easy to put back on the same way.
This is what I've always done with every car I keep covered, if you roll it the same way each time, it makes it very easy to remove & replace.
I'm currently having a '28 Ford Roadster painted gloss black and I've done a fair amount of research on how to keep a black car scratch free, some high-end paint shops actually recommend using painters plastic (think very fine plastic sheeting) under the cover to keep the dust particles away from the paint.
Also, if you wax the car, always go in a straight motion along the cars lines rather than in a circular motion which will actually inhibit scratches.
I just know this car is going to drive me bonkers trying to keep it perfect but alas, gloss black was my only choice...
buickfunnycar.com (06-30-2014)
vinny jones
10-05-2015 07:20 AM
KarimPA
09-12-2015 08:15 AM
