Clutch finally bit the dust
2016 MT with 13K miles and 1 year of warranty left. It won’t shift into gear with engine running. I had to turn of engine, put it in 2nd and drive to the dealer(about 5 miles) all in 2nd gear. Then I had to show them how to put it in reverse in order to get it in a parking slot. They can’t check it til Wednesday. I don’t know how long to get the parts. Planning to drive to Mendocino on the 7th( if it hasn’t burned down) so I hope it is done by then. I’m probably the last one to get my clutch done of the MY16s.
Got a call from the dealer this afternoon. They could not find a problem. Drove there and test drive with mechanic. It drove fine.
Their driver verified that it would go into reverse when I dropped it off. I took it home and will drive it and see if it happens again. I’m thinking a hydraulic valve sticking and not letting clutch fully seat. We shall see but no new clutch yet.
Good luck.
That was symptom #3 for me. Something has come apart and a piece is floating around that will make this recur. I'm not sure if it's from the clutch or the dual-mass flywheel, but I had the same thing happen. When I dropped it off it was showing the symptom, but the next morning when the tech tried, it was working fine.
Good luck.
Good luck.
