View Poll Results: How does your clutch work on maximum acceleration during a 1st to 2nd gear upshift.
Voters: 57. You may not vote on this poll
Clutch Satisfaction
#321
#322
Contrary to expectations, mine remains ... adequate. I've had instances where I just had to back off until it grabbed but they are rare, even when I drive it hard. I will again complain when I next bring it for service, but I can't replicate the condition at will. I suppose if I deliberately got it slipping badly with partial clutch pedal and then let off on the clutch with continuing full throttle it'd do it, but that's a bit abusive.
#323
#324
#325
oh...I thought you had yours swapped out. You should bellyache about it to the dealer and get a righteous clutch. Tell them it's been slipping since day one.
#326
#328
I almost always drive in TracDSC, but almost never with it completely off. In TracDSC I can go to 6000+ and, as you put it, slam second, and it does grab. I'm not sure, but I think the times it's slipped egregiously I might have been slow on getting off the clutch pedal.
SinF (05-14-2017)
#329
+1. She'll go straight to redline in second if the clutch isn't holding. The updated clutch has no problem handling 450hp/425tq.
#330
#331
The easiest way to check is to pump the clutch a few times while at a standstill. If the pedal action feels a bit firmer on the forth pump vs the first, you have air in the line.
SinF (06-01-2017)
#332
#333
I've got the 2nd gen clutch, 2nd gen flywheel. Went to get service today for warrantied o2 on the manual, and got a loaner of an JK R sedan (*see below).
But basically, my dealer who I love, and service guy said he knew about the 3rd gen, had just installed one last week, but because I got the 2nd gen, and it is holding and working great, at this point it is considered wear and tear, and I will pay for a new clutch in the future, and it will be 3rd gen. But it isn't considered warranty and I don't get it updated for free. I am no pushover, but this sounds reasonable.
What do you guys think?
*Prior to even finding dynamic & sport mode, I experience, for the first time in my entire life, performance automatic shifting. I've had Toyota or Hyundai rentals, but never truly experience an AT at speed. Holy ****. It's slightly different than my late 90's Honda when I was younger. It's.... all I need to know I will someday end up in an automatic. Holy **** guys. I can't believe what 3 decades of engineering can do.
#334
The following 2 users liked this post by Unhingd:
SinF (07-05-2017),
Uncle Fishbits (06-14-2017)
#335
Mine seems to be finally heading out to pasture. I've had a few times now where it seems to drag (not the usual complaint) and I couldn't engage a gear when stopped without shutting the engine off.
I'm hoping it doesn't fully 'splode but reaches a point where I can say to the dealer, "See? That's not right." The official test (2K rpm, 4th gear, see if it stalls) hasn't failed yet, but things are declining in Lizzardo Clutch Land.
#336
#337
#338
I was to bring it in yesterday morning so spent time Saturday trying to characterize the issue better. It was working normally again so I cancelled the appointment, although I did explain the situation to the service adviser.
I drove to work in it yesterday and it slipped badly once on a hard launch, and was again dragging when I went to leave work, but with some occasional lurching on engagement.
If it's finally packing it in then it should be easier to explain to the dealer. I guess there's that.
#339
One step ahead of you there. Considering that "normal" is already spongy it's a subtle thing. The pedal felt like it usually does. It was dragging a little when I got home one day so I took the Miata to work for two days (they're repaving the parking lot at work so that's been my usual lately). It still dragged the next time I went to move it so I made an appointment at the dealer.
#340
Based on production date, I think we decided long ago that it's a Gen 1. It's an early production car, delivered in July 2015. And yeah, I think it's going Tango Uniform. I'm really busy right now but need to get it to the shop ASAP.
