code p0430
The P0430 code doesn't mean the cat is necessarily bad. It indicates "catalyst inefficiency" and that is based on comparing the readings of the sensors fore and aft of the converter. If it sees that there isn't enough difference between the two it throws that code, but I would look to the sensors first as they are a known issue.
EDIT: Since the warranty for the sensors has been extended, I'd recommend having the dealer diagnose it. If it's the sensor(s) it should be fixed at no charge.
cwisenheimer (06-30-2024)
