Code P2138?
Code P2138?
This has been an interesting week for codes on my 2017 F-type. Saturday "restricted performance" appeared on the dashboard, my obd2 code reader read P2138. According to Jaguar's website, P2138 = Accelerator Pedal Position (APP) assembly failure, Powertrain Control Module (PCM) failure, Throttle Position Sensor (TPS) failure, Wiring issue. I did not reset the code and immediately drove it back home.
I didn't drive the car on Sunday.
Monday morning, I called my local Jaguar dealership as it is still under warranty. They recommended bringing it in immediately. When I started up the car to drive there, the code had cleared itself and nothing on the dash indicating an error. I called Jaguar back, explained the code was not active and scheduled an inspection for this coming Friday morning.
Code came back on Wednesday with a check engine light as company but no "restricted performance" error.
This morning (Thursday), code again cleared itself and no check engine light but I had "low battery" warning on the dash.
Is it Friday yet?
Is it Friday yet?
The low battery warning after using an OBDC device could be the well-documented ODBC problem, not necessarily indicative of a bad battery. Even a good battery will be low after sitting overnight with electronics active. That's not to say the battery doesn't need replacement. My car is about that age and on its second battery.
The code reader was only plugged in for a few minutes. But, I do have a dash cam installed (I purchased one for my previous car, 2015 BRZ, after I was involved in a hit and run). The dash cam never drained the BRZ battery. The F-type is driven everyday and long trips on most weekends. It sits in a garage at both home and work, so the motion detection shouldn't be triggered often.
I just unplugged it.
Definitely going to have the battery tested at the dealer tomorrow.
Thank you for all the feedback.
Look for the warning triangle on the dash before you turn the ignition on. If it's lit, the ECU never went to sleep.
pjazz (01-24-2020)
Has rescued me once to restart the car (OEM battery) and once to open the boot to push the reset button on my primary lithium battery.
https://www.ebay.com/itm/PUSHIDUN-Ju...AAAOSwsnVeHcSS
The following 2 users liked this post by Unhingd:
GGG (01-24-2020),
peppersam740 (01-24-2020)
Interesting tool, such lithium starter. For >3,5L they recommand a version with more capacity.
Concerning battery life I have one tester, also from Ebay. I already found some near to dead batteries with this one :
https://www.ebay.com/itm/Auto-12V-Di...wAAOSwHglcLyf~
