Hi everyone, first time poster and I'm hoping someone can help me solve a bit of a mystery with front bumper parts. I have a 2018 F-Type SVR and I scuffed up some of the plastic pieces on the bottom and looking to replace. The mystery item is a plastic piece UNDER these two deflectors that stretches from one side of the car to the other.
I don't see this part listed. I see two items they are calling Side Spoilers (L&R, T2R11276, T2R11277), but this thing I'm seeing on my car is one piece.
I don't have an SVR but I am fairly sure you are talking about the "under cover", part # T2R20597 and # 13 in the graphic.
I have removed this piece a few times on my 2014 S coupe and it's a PITA coz it uses around 3,457 bolts and screws, and I think it's the same part across the F-Type range from year to year and model to model.
A bit of clarification. This mystery piece is under both side deflectors and center deflector. It's one piece stretching from one side of the car to the other. One of the side deflectors shown in this pic below:
Side deflector
Doesn't change what I think, I still reckon it is part # T2R20597. Those side deflectors bolt on top of (under) it.
Check to see if the part you are after extends back under the car by about 50 cm and if it does then it is T2R20597.
With such a big front splitter on your SVR I wouldn’t even both replacing it as you can not even see it. It is a sacrificial part anyways and will only last until you next spoondrain or driveway mishap. Cheap to replace if you still want too though
