Considering a coupe and looking for some advice
#141
I'm not confident that a $12k drop in price in less than a year is realistic, but I'm hopeful that the release of the 4 cylinder F-Type has an impact on the used car market since it lowers the price of entry, and hence increases overall F-Type sales. The downside being the Jag is less rare on the roads.
#142
Received 3,263 Likes
I'm with our friend intotheblue, I really wanted an R but here in Oz the price differential between an S and and R is huge, around $40 - $50k for a two or three year old example, and I simply could not afford an R. When my current S came up at a bargain price just within my budget, with nearly all the options I wanted, I jumped at it.
That's not to say I still don't lust after an R but they would need to drop another $50k before I would be tempted.
#143
#145
#146
Don1954 (09-29-2017)
#147
If you intend on hooning, RWD is a must.
AWD largely solves this problem, you can put down power from standstill more efficiently. BUT the car is heavier and all this weight is at the front and that compromises handling. I personally prefer RWD, even if AWD F-type is likely faster in corners and faster off the line.
#148
RWD F-type has issues with traction, you can't go WOT from standing still. For example, last night I was returning from track day, car was still in the track mode with everything off. I was turning from side road onto highway and went too heavy on throttle. Ended up doing rolling burnout. With warm tires on a dry pavement.
The 0-60 numbers for the AWD look to be .1 second slower, so I guess the weight really suffers. Obviously not a big deal, but some AWD cars are significantly quicker than their RWD counterpart.
#149
I prefer the RWD to drive, it feels much lighter at the front end though I've only driven the AWD on the track and some reviewers thought the AWD was better.
Traction isnt so much an issue in the RWD that it interferes with launch like it does in the XKR, but it will step out if you give it the beans, even in normal mode. I think they are designed to.
#150
I just posted up a new thread about whether getting the 380W sound system and adding in my own 12" sub would suffice vs the 770W as that helps me stay within a better budget. Anyone have any thoughts of that here?
#151
While I would prefer a 2016 White V6 S with Design Pack and silver wheels, if this car happens to be available in 2 months I think I'll get it. Green is tied for my 2nd fave color, unique interior color, has all the other options I want; vision pack; pano roof; Meridian Surround; and I can live with the black wheels. Aftermarket extended warranty will cost $5000 for 4 years and I should have less grief with buying the VAP tune.
https://www.cargurus.com/Cars/invent...ting=180485800
#152
Yes, but the car does this buy cutting your throttle and pulsing brakes. This makes you slower. Better tires help, but not solve this problem. With Pzeroes I could spin rear tires in second and on a cold day in third. That is, unless you are accustomed to driving muscle cars, you need AWD. You can't just mash throttle on RWD. Most people just mash throttle.
#153
#154
#155
#156
#157
Traction control on this car is really well designed, even when it goes all-out correcting you might not notice it with a car equipped with an automatic gearbox. Because I drive MT, I have more direct feedback into what the drive train does.
If you are an adventurous type, try following. First, stomp on accelerator from stand still on a flat dry road. Watch the car just go. Second, turn traction control completely off (hold button for 10 seconds), then stomp on your accelerator. You immediately will see what traction control does.
However, be careful as in second case the rear will become loose, this will point your car sideways and rapidly push you that direction if you lift off accelerator. Very easy to end up in a skid and there is no traction control to bail you out. That is, to correct you need to gradually reduce throttle while counter steering or you will risk ending up in a ditch/wall.
#158
#159
#160
