OK, photoshopping skills are poor and wheel image angles are wrong, BUT how do they look?
A lot of people opine that wires are only for old classic Brit cars and have no place on modern cars, and there is the stigma of the whole 'lowrider' thing.
Plus - practical issues with cleaning, air leaking (Daytons are sealed for tubeless tires, but people have problems sometimes) and adjustment (Daytons are *supposed* to require no adjustment - ie 'truing'). Also, they are heavy. They can handle the power tho, so apparently that's not an issue.
I like the way they look as long as they are real spokes with clear view of the calipers (not spokes added to the front of an allow wheel). Don't even think of putting them on an R and also they would be ill advised if you plan on tracking a base or S. They just can't handle the power and lateral g forces of the modern performance cars. They've been banned from racing (except maybe vintage racing) for half a century.
Just curious . . . are those knock-offs like original wire wheels were, or bolted on with lug bolts/nuts? Had knock-offs on a Shelby Cobra replica, and they always made me nervous.
I never had them, but just the idea of knock offs makes me nervous too.
They make several kinds, including bolt ons in pretty much any bolt pattern and knock offs (you get a LEAD hammer with a set). They also make 'spline drive' wheels for old Brit cars that use such.
The XK ones were bolt ons.
Their website seems to assume the 'Wire Wheel' checkbox on your Man Card has already been checked, as they really don't explain the options at all well or even explain what is possible. The bolt-ons do seem the safest bet, however the spokes seem to be arranged in a less 'dense' pattern so that the lug nuts can be removed, so while they look good, I think the knock off patterns look better, at least the pics I've seen.
No question that the bolt-ons would be the safest, and also no question that the knock-offs would look better. There's something about bolt-on, wire wheels that is just a non-sequitur.
I just don't think they belong on an F-Type. Even though it pays some homage to the E-Type, which looked fabulous with knock-off wire wheels, it is thoroughly modern design.
It's kinda like putting 20" low-profile tire/wheels on an AC/Shelby Cobra or E-Type, etc. Wire wheels only work aesthetically on tall tires (60/70 profile) with a lot of sidewall, which provides that vintage, very old-school look.
I certainly agree that putting large low profiles on a vintage car looks mostly to very wrong because they were never made that way, and the technology didn't exist at the time, however, I'm not so sure that the concept of wire wheels itself should be totally written off. I'm also not sure that they can't work with lower profile tires than those fitted to the classics.
These all look pretty good to me, (they're horrendously expensive Italian Borrani wheels) and they seem to have gone exclusively with a bolt on fitting, (which must be for engineering reasons) and the central bolt on hub isn't totally to my taste, BUT... I think they work, at least with some modern cars with a more 'classic' design - and I think the F-Type is a 'classic' design.
Actually, that is the only choice you have. Retrofitting to the splined and threaded "axles" would require a massively and expensive customizing of the axles and rotors. Back in the sixties, the british SCCA cars were were required to convert to bolted (steel or alloy) wheels for safety reasons. That was not a serious issue since bolted systems were typically offered as one of the options and the parts were readily available.
