Coolant Pump
I read on other Jaguar model's forums that AJ engines had a flawed engine coolant pump that was prone to leaking, and that issue was remedied with an updated part around 2016.
I believe we share coolant pump design, however I have not read about pump failures here.
Is this an issue? If so, what MY does it impact?
Remember a couple mentions of this too. On my 2015, I smell anti-freeze every time I pull the car back into the garage, but I do not see any signs of leaking on the floor. And the coolant reservoir was down about a pint of coolant on the past 6 months - been meaning to take it in to my dealer....
I had the same symptoms as Chawumba.....maybe a little more than a pint when I checked. Never did get any warning about low coolant or see anything on the ground, but I could smell it.
Dealer replaced water pump and said something about a bearing wearing out in the original which would cause a slow leak.
I still think I can smell coolant occasionally, but the level hasn't changed noticeably since the repair.
These are the superseded part numbers: C2D20660, C2Z30684, C2Z28248, C2Z29189, C2Z31146, C2Z21781, AJ812119
Lawrence.
