Cost to Replace all the sticky peices
Dealer seems unsympathetic.
I have a version of the same theory that sunscreen is also adding to the problem. Snscreen will destroy just about anything and a lot of people in the convertible are obviously using it.
David Meier (04-06-2020)
i notice it is the grayish matte finish parts framing the shiny parts that give the issue. Frame around door handle, frame around l/r a/c vents, steering button frame, etc. when u rub it off, its shiny black underneath and thus changes the look. It’s hard to achieve perfect finish without looking blotchy if u rub it off.
I have shiny black parts around touch screen and carbon under a/c so its not an issue there, thank goodness. One hidden benefit of those options apparently.
I agree it will do little good to replace with the same parts that will just get you past the warranty period and occur again down the road.
Anybody know for sure if replacement parts are fixed with new coating or finish?
Would removing those parts and clear wrapping when new be a preventative option? Can those parts even be removed without breaking?
This is by no means an exclusively "Jaguar problem" - many makes used this same finish to their buttons and switches with the same result. And it won't make a bit of difference to the resale value of F-Types. Often only "real world" experience reveals the durability of finishes...a perfect example is the nikasil cylinder coating used by both BMW and Jaguar in the 90's. Both companies were faced with engine replacements when the engines faced two failure-contributing factors: high sulphur content fuel and very short active engine periods - moving a car out of a garage to wash it, for example, the restarting and putting it back in the garage. Done enough times, this resulted in the excess fuel in the cylinders damaging the nikasil coating, resulting in a lack of compression. Could this have been foreseen? It could be foreseen in hindsight! It is very easy to pillory manufacturers as though they produced defective products on purpose. The truth is that they work very hard to build quality products, but sometimes....
And a very simple, easy, cheap and permanent fix for this problem is to simply coat the vulnerable switches and other pieces with a satin finish varathane - brushed on. This is effective and especially useful for the pieces that receive heavy use - the audio on/off button, for example, and the P switch, but it works on any of the coated parts. It is much faster than removing the existing finish and it leaves a durable coating.
#28
a. This is directly related to heat and UV. If you let your car bake in the sun, then it will happen sooner.
b. This eventually happens to everyone, but range is more than a decade.
c. You can't clean it off without damaging finish, your choices to replace parts of live with it.
d. New parts will last about as long as old ones did, if your 2015 car has this issue then by 2025 it will happen again. Invest in a windshield sun shade and park it in the garage when possible.
#30
#31
You what this behaves likes- feels like- looks like; Plasti Dip Clear.
Someone should try using plastidip to recoat.
#32
David Meier (08-30-2019)
#33
#34
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/img_20190824_124605_f681e1322925e0ffc281658096ca238bb156e616.jpg)
I am having a similar experience. In the last 4 months I have started experiencing the "sticky button" issue on the eco button pod and the top of the steering wheel. I have a 2014 V8S convertible that is a garage queen. Even though I live in Atlanta, the car is stored in the garage and rarely sits outside. It has less than 17,000 miles on it giving you an idea of how much time it is inside. In my opinion there is definitely an issue with the rubber coating breaking down prematurely, but I am not sure I would point to environmental factors like UV/sunlight as the culprit exasperating the issue. I would love to see Jaguar address this issue, but given the age of my car, I have my doubts on any warranty type response. Regardless, I am very interested in others experience in removing the rubber gunk or replacing the buttons. It will be a project that I will be looking at in the near future.
#35
Also, does the urathane bond with the sticky coating? Again it must or it seems like putting a hard shell over a soft under layer would just crack out over time.
How did u keep the urethane from getting on your leather? Did u mask it off with tape or use tin foil?
My 2016 only has 7 sticky parts. L/r door handle frame trim, l/r a/c vent frame trim, center vent trim, bottom steering wheel trim, and the console grab handle bottom trim. My start button, parking brake etc buttons, upper steering wheel buttons and part #2 are not sticky and do not appear to have ever been coated.
New replacement parts are not supposed to have this issue and new models seem not to have it. Anybody know at what vin numbers they quit using sticky coating completely? Or, is it still an issue?
#36
#37
I had the same problem. Jag wanted 6k to fix mine. 17% alcohol will clean up the sticky parts but it’s very time consuming.
#38
#39
#40
Received 2,192 Likes
JgaXkr (09-08-2019)
