creaking sound
Hi everyone,
I have a 2018 v6 manual F-Type and it often has a creaking noise, most prominently when I go around curves. It sounds like it's coming from the back roof area and I have been told maybe it's the panels rubbing together. I heard there were small teflon pieces that can be put in between the panels to stop this. They haven't been able to help me at the dealership.
Has anyone had the same issue and a solution?
Thanks!
Nick
Thanks!
Nick
Hi everyone,
Thanks!
Nick
Thanks!
Nick
Received 3,226 Likes
Mine creaks and groans from the rear on both sides, especially on speed bumps or when accessing driveways.
Only started doing it a year or so ago, straight after I hit a massive speed bump at 70 km/h. The speed bump (well at least the next one!) was signposted at 20 km/h but I never saw it as it was hidden in tree shadows. Made an awful thump thump as I went over it, but when I inspected the rear end later I couldn't see any signs of damage.
I'm with the Unhingd one, I reckon the impact shock loosened the bond (glued) joints at the rear, where the rear quarter panels are bolted and glued. When I push down on the rear fenders I can reproduce the creaks and groans, especially with the hatch open.
There is a fix. There is another thread explaining how the Jag authorized body shop disassembled the body and rebonded the creaking body parts.
Hi, I'm in the process of purchasing a 2014 f type s v8 and I noticed (what appears to be) this same creaking sound. The dealer is deciding if this is something they want to fix or not. Is this a big problem? Would it deter you from purchasing? 2014 Jaguar f type S V8 convertible optioned out. 67k miles. $34.2k
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
ha, a bit of self promotion for you. Lol
https://www.jaguarforums.com/forum/f...panels-243503/
press on those spots as indicated in my guide and if it’s the same sound then go ahead and buy your car as super easy fix. Alternatively you can just apply Tessa tape to that bottom trim piece instead but didn’t think of that before
There is a video around here somewhere showing F-Type construction in the factory and because the frame and panels are all aluminium there is zero welding, rather the panels are fixed - "bonded" - to each other with glue and rivets. There are still plenty of bolts holding most panels to the frame.
bradmatchung
09-17-2020 06:12 PM
Dell Gailey
08-23-2018 03:07 PM
