creaky
Hi everyone,
I have had a very annoying creaking sound when going around turns at higher speed and now have figured out that it has to do with the covering of the cargo area in the back. When I remove the cover the noise disappears completely. The first cover I had seemed too small as it became separated from the end posts so I got it replaced thinking this would solve the problem. However, it's still there with the new cover as well.
Has anyone had this same issue and a potential fix? (Besides just leaving the cover off :-))
Thanks so much!
Nick
Thanks so much!
Nick
Received 3,231 Likes
If the JTB grommet fix doesn't work just do what I did - remove the cover and wrap black electrical tape around each mounting peg, 10 or 12 turns should do it to get a nice tight fit. You will have to use some force to push the slots over the pegs after wrapping them (do it from each side while firmly holding the part where the peg is mounted), but they should push all the way in and fit so tight that they don't move at all (other than rotating) and give off zero rattles or creaks.
I did this over two years ago and nary a squeak, rattle or creak ever since and still with the original wrapping.
Thanks for the suggestion. I had a creaking/squeaking on bumps that turned out to be coming from the cargo cover pegs. I applied a light coat of oil I had on hand, which resolved the problem. After some... spirited driving, the creak came back. Reapplication of the oil has fixed it again, but I've ordered some silicone grease which I'm hoping will be a more permanent fix.
vdpnyc
11-11-2016 08:04 PM
pdr1966
05-20-2010 04:17 AM
