Cruise Control Deceleration Question - Just Me?
Anyone else find this infuriating (or is there a problem with my car?) about his/her F-Type (mine's a '14 V8 S):
So, once the cruise speed is set, you can then accelerate by 1 MPH increments by tapping the + button for a second (the display will show the new 'cruise speed' on the center TFT). 3 quick presses raises the speed by 3 MPH, 4 presses by 4 MPH and so on. However, to reduce the cruise speed, you have to hold down the - button, wait for the car to decelerate to the speed you want (which it never consistently does) and then release the button. You can't slow it down in 1 MPH increments by tapping the - button, so I always overshoot the speed I want and then have to adjust upwards again to compensate. Sometimes, it takes a few seconds for the car to even begin slowing down.
And I can't believe the Cruise Control doesn't apply brakes on downward slopes to prevent the car from accelerating past the set speed. My 2008 C300 and my mom's 2006 330Xi do that!
Mine will go down in 1 mph increments. But I have never had a car that applied the brakes with Cruise. However, I have had cars that will downshift to slow down the car. Never liked that. Yes, the Jaguar will just keep going faster if you are going downhill, although I have not tried the speed limiter function, which would probably stop you from accelerating.
Larry
Larry
Thank you for your reply.
Larry
Larry
Thank you.
I have also tried double and triple taps of the - button but nothing seems to happen. I don't get any deceleration until I've been holding the button down for more than two or three seconds. The + button works on 1 MPH increments, so I will see whether two quick taps makes any difference.
thanks
That's interesting.
I have an appointment scheduled with the dealer for next week (second time to sort out an annoying buzz from the fold-down center arm-rest caused by the stereo) and will add the CC as an issue to look at if my car doesn't slow down in those .5 MPH increments.
Thanks so much for your comment.
The cruise control goes up, and down, in 1 unit settings (could be mph opr km/h depending on your setup). There is no half unit settings, however you do need to press the down button momentarily longer than you do the up button for it to register the change. That may be where the confusion is coming from. If you press the button firmly till it hits the stop then let it return then it will always lower the set speed by 1 unit, but if you just tap it quickly like a volume button it requires two taps.
Why? If deliberate then I suspect it is to prevent people pressing it by accident, or if not then as the selected switch is detected via a resistor ladder it is possible it may take fractionally longer for the voltage to get to the required value for that one button versus the up one. Either way, a firm press always reduced the speed by one unit on my car.
Mbourne (10-08-2016)
Received 3,229 Likes
I checked out my cruise control up and down buttons yesterday, and they both worked perfectly IMHO. The up button increased the speed by 2 km/h with a single gentle press, and the down button decreased the speed by 2 km/h with a single gentle press. I didn't reset the units to see what happened with mph. Remembering that the rough conversion factor is km/h = 1.6 x mph.
The ASL in mine does not get overridden by pressing the go pedal to the floor, at least not by pressing it slowly. I've never tried nailing it with the ASL on.
And my CC doesn't work well. It is difficult to engage and the + - buttons are slow. The one time that I had the dealer look at it they found no problem. I know there is, but until they agree...
Originally Posted by
So, once the cruise speed is set, you can then accelerate by 1 MPH increments by tapping the [B
+[/B] button for a second (the display will show the new 'cruise speed' on the center TFT). 3 quick presses raises the speed by 3 MPH, 4 presses by 4 MPH and so on. However, to reduce the cruise speed, you have to hold down the - button, wait for the car to decelerate to the speed you want (which it never consistently does) and then release the button. You can't slow it down in 1 MPH increments by tapping the - button, so I always overshoot the speed I want and then have to adjust upwards again to compensate. Sometimes, it takes a few seconds for the car to even begin slowing down.
oxigen sensor fix K309 . Prior the fix I was able to adjust the speed in 1km/h increments up and down so I think it's a software related problem caused by the ECU update .
Being out of warranty no chance for me to get it fixed by the dealer anymore.
Regards
Ulrich
orangeblossom
05-20-2014 05:54 PM
Roadhouse
11-04-2010 06:26 AM
