Cruise control missing
In BMWs they don't offer rear fog lights in U.S. spec models, but you can add it just by replacing the headlight switch with a European model switch. Perhaps adding the switch would also add the feature since it isn't that complex. Many times its cheaper to just take away the switch than make 2 different wiring harnesses/software packages that increase plant complexity.
Received 3,226 Likes
This is probably the most likely scenario, but its possible you don't need to tweak anything. Being there are no switches, the system could technically be active all the time without any issue. This would reduce plant complexity when initiating the vehicles.
Help!!!
Without Cruise control this car became a bit annoying on longer trips, my knee and foot got numb all the time...
I really need to find a solution for this perhaps someone can indicate a expert that might can solve this.
Arden told me they can only sell me the steering wheel but no coding the CC buttons....
[QUOTE-bcbruno;2248952] ˇˇˇAyuda!!!
Sin control de crucero este coche se convirtió en un poco molesto en viajes más largos, mi rodilla y el pie se adormeció todo el
tiempo...
Realmente necesito encontrar una solución para esto tal vez alguien pueda indicar un experto que pueda resolver
esto.
Arden me dijo que sólo pueden venderme el volante, pero no codificar los botones CC....
[/QUOTE]
Hola,
Alguna noticia nueva sobre su duda, tengo el mismo problema.
Gracias
tiempo...
esto.
[/QUOTE]
Hola,
Gracias
scm (07-29-2020)
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
