So I know there’s loads of threads in this,Just after connecting up Ctek trickle charger I had, used to use on my xkr, just hooked up the tender and left in the boot, ready to connect to the power, I just went with simple hook up to the battery in the rear, positive to power on battery and negative to a bolt in the body that was holding on a bracket, as per pictures , I have seen the pictures of how to fit but my 2018 4 pot seems to be different, do you think I have it wired,
The last picture is the regular fitting picture then mine as you can see is different, I’ve wired showing yellow arrows
