Curb tire damage
The following 2 users liked this post by scm:
89 Jacobra (11-09-2022),
Carbuff2 (11-09-2022)
The following 2 users liked this post by Ftypedickie1:
BruceTheQuail (11-09-2022),
TLW-STL (11-09-2022)
It's hard to say how thick the rubber is in this area without taking the tire off. However, if there are no cords cut through, it could be structurally intact. Sometimes the area above the bead is very thick, as this helps steering response. In other words, most performance tires are stiff tires, and are that way due to being thick and strong. The alternative way to build a tire is to make it lighter and use higher pressure for good steering response. You see this with cheaper "performance" tires from China.
If that were mine, I'd clean it up, inspect carefully, monitor the tire pressures closely and go on my way.
First Place Wheels in Jupiter, FL can easily repair that rim. I'm guessing the repair would cost well less than a new replacement. But maybe you can find a used rim on eBay or?
You can glue rubber back together with specialty rubber cements and/or heat vulcanizing. The vulcanizing process is really beyond the capacity of a roadside repair. But common CA "superglue" might hold that flap down just fine, as long as the rubber is very clean before a glue attempt.
It is worth looking on Youtube to see how massive truck and heavy equipment tires with 3 inch chunks "missing" are repaired.
Yeah I think that ridge that has been torn is just the protector for the rim. Some tyres (eg the PSSes) have it quite pronounced, and I look for it in a tyre to try to avoid rim damage.
It looks OK to me, I'd get a tyre place to check it and unless they said anything different, I'd glue it down.
I did something similar to mine about 3 years ago, glued it down, no dramas.
89 Jacobra (11-10-2022)
Replacement wheel for my 2022 F-Type, 20" from local dealer was $1287.06. They repair and repaint wheels for $150.00 per
Thanks for everyone sharing their knowledge and experience! I decided to continue driving on the tire and after ~500 miles today everything is still OK. Will keep monitoring the tire for bulges.
As a bonus I stitched together some footage from the dashcam on the escape from the parking garage that caused all this. Still amazed I came out of there without a single scratch to the bodywork of the car.
cujet (11-12-2022)
The building was erected in 1976 so it's not like it's a 100 years old. Just your general southern european poor engineering on display. Booked it after reading booking.com reviews of the fantastic parking in downtown Madrid 😅
