Curious on opinions
Curious on opinions
Curious -- Just ordered Continental Extreme Contact Sport tires online (new) and the two fronts I received are just about 3 years old. (One more slightly more and one slightly less)
Given that we drive "sports" cars and we go through tires relatively quickly, would you guys be okay installing 3 year old tires or arrange to have the tires returned and swapped for a set?
I'm inclined to send them back, but am trying to gauge if I'm overthinking this a bit...
You ordered online, you got new tires delivered. Unless there is something in the advertisement that would contradict 3 year old tires, it is on you.
Next time, if having just-made tires important to you, don't go looking for a lowest price online, instead go to a reputable tire shop that moves a lot of tires and tell them you want "not older than x" tires.
Also, if these tires were warehoused, there is no issues at 3 years.
Jaggyx (07-21-2019)
That being said, a few assumptions are being made above: 1) That I looked for the lowest price online, and 2) that a reputable tire shop would stock these tires.
I've done some digging on this issue, and TireRack (I'd say a good reputation) has been known to send tires a few years old as well. More so, shops don't exactly go pull Continental Extreme Contact Sports from the shelf in 265/35/ZR20, they're all placing an order from somewhere. I could make a request that they provide newer tires, but then again, I'm not taking $4,000 forged wheels to any "reputable" tire shop that's stocking these sizes. Most smaller boutique shops, the only ones I'd trust, are going to order from Tire Rack -- also negating that going to a reputable shop would have solved my issue, which seems to be a non-issue now that I've read a bit more and gathered a few opinions.
I agree -- I'll most likely burn through them within two years anyways. Thanks.
https://www.wikihow.com/Prevent-Dry-Rot-on-Tires
Dry rot results in the loss of the special chemicals that keep your tire's rubber soft enough to ensure a good grip on hard pavement.
The following 2 users liked this post by 67ECoupe:
BruceTheQuail (07-21-2019),
RyanMiller (04-12-2022)
Dry rot is more of a concern when the tire is under load (i.e. installed on a wheel and the wheel is on the car, and the cars weight is being supported by the tire). As long as the tires aren't exposed to sunlight, liquids and cold weather (and these are unmounted tires we are discussing here), dry rot is not an issue for many, many years. Pretty much any big business tire warehouse keeps their tires well away from the elements.
GoobeGustafson
08-05-2010 09:22 AM
