Custom Exhaust
So I have already gotten rid of the huge muffler that our cars use but I am taking it one step further with downpipes.
In order to clean it all up, I will be getting a custom medrill bent system build from the headers back, an x-pipe and dual single chamber mufflers out back.
Our current set up is 2.25" piping and I know it is that way all across all the platforms, but will a 3" pipe yield any benefit?
The price difference is marginal between the two so I wanted to see if this will do anything what so ever.
I have the V6S AWD model and future mods will include a pulley, tune and either a custom build intake or possibly the Eventuri one.
Any advice/tips are welcome
The biggest issue I have right now is the butchered job that was done by an exhaust shop.
The pipes are bent all wrong and it is leak city under there, meaning I will HAVE to replace all of it before I go insane. Do you just recommend the 2 1/2" piping for now then and then grab the tune etc?
F-Type V6S Coupe
Look at the bottom, these guys make unique and awesome products, definitely stands out from any other exhaust! Very high quality too!
Problem is this:
With them I can get a downpipe and the muffler/tips.
This still leaves the entire mid section of the car along with an X-Pipe needing to be fabricated.
The price of Downpipe and Muffler from them exceeds the cost of doing a custom downpipe, mid pipe, x-pipe, and dual single res mufflers and 4" tips coming out the back.
No matter if I go with theirs or a custom one, without headers and a lot more boost, the HP increase will be marginal from the exhaust so I have a hard time spending way too much money on it when there are other mods I would like to get done ASAP.
If it is large enough to manage that output level and the airflow from two more cylinders, then there's no way that your V6S is being restricted by the tube diameter.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
![](https://www.jaguarforums.com/forum/signaturepics/sigpic147732_1.gif)
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
He is going to do the exhaust, so the best advise is to do it before the tune. My experience:
There will be loss of torque on the low end of the rpm. You will notice that sometimes, when you press on the gas, the car seems to not respond as hard, and sometimes it will push really good. Depends on what part of the firing sequence you hit at the time of launch. That is what happened with my old XF. I did the resonator delete and straight pipes to the rear boxes and torque was intermittent. You wont like it. But...if you have the tune planned, then that will provide overboost and give you the increase in back pressure to correct that. I never got around to doing a tune on my old one, but plan on getting my new XF tuned this month. Exhaust Authority will get you a cusom exhaust and they can bend aluminum pipes in house for weight reduction.
The Eventuri intake is one bad *** looking part !! It would look so tight inside the engine bay!!!
Burt Gummer (02-01-2017)
