Custom wheel suggestions
All,
I am thinking to build a set of custom wheels for looks and better fitment in my wheel wells. I have the carbon ceramic package wth BIG calipers and I don't like the only wheel choice I had (storm wheels). I have had two sets of custom Boze wheels in the past. Just looking for options. I want the offset perfect. Probably would like to have someone measure for that perfect offset. I am in Texas.
I believe the current wheels are 9X20 255/35/20 55mm offset and 10.5x20 295/30/20 38mm offset.
Thinking 9.5X20 and 12X20 for Michelin PSS tires. Maybe 275s and 325s?
Going to do something slick. Looking for suggestions.
Forge vs Cast. While yes, HRE are expensive ... you can argue they are overpriced, you are getting better constructed wheel.
There are other custom forged companies that make a quality wheel at a much lower price point. i'm not sure i would put a Chinese made cast wheel on a 100k car.
*edited bc autocorrect fail*
There are other custom forged companies that make a quality wheel at a much lower price point. i'm not sure i would be a Chinese made cast wheel on a 100k car.
There are plenty of great wheel companies with solid quality forged wheels at a reasonable price include Rays, BBS, SSR, Work, Advan ... just to name a few. The main problem for us is that they are all made for Euro and JDM spec - very few have offerings with a 5x108 bolt pattern.
We have very limited off the shelf options because of bolt pattern ... except for alot of the cheaply made cast wheels with no QC. You have to go with a HRE, Klassen, Velos. The other option is a lesser priced custom forged wheel like Rotiform, BC Racing, or similar ... most of these wheels are all made at the same factory.
Anyone knows that certain wheels are better than others but do you really think any wheel is so dangerous that it's unfit for market?
If you put a $250 wheel on your car, you are not being irresponsible guys. Yea you can go forged and spend a $1500 per wheel but unless your tracking and need weight benefit, any wheel is perfectly fine for city driving. Any wheel company who would ever get a reputation for producing a wheel thats prone to failure would do so much harm to their brand that they couldn't sustain as a company. Firestone almost died because of their defective tire years ago. Wheels generally work well guys.
Without starting a war here, let me say this emphatically...
NO ONE ON THIS FORUM drives their F hard enough to go beyond the practical limits of any wheel you choose that is being regularly sold.
You don't have to preach the benefits of this type or that type, really...
Get the wheel you like and if you can't find the right bolt pattern, get a set of adapters if you truly need that wheel.
None of us push the car to the point that we have to make any wheel decision other than style. Don't let anyone tell you different. I've run aftermarket wheels all my entire life (hundreds) and have NEVER had a wheel fail where it hasn't been my fault. EVER. Never had a wheel leak or split without me being the one to hit a curb. All wheels are made in China regardless of what brand they are unless, as stated earlier, they are milled in one of a few houses and remarketted. Bottom line is Forged $1500 a wheel, cast $250 a wheel. get what you want. The truth is that it's always far cheaper to simply replace a bent $250 wheel than to recondition high end HRE's or Forgiatos.
OEM wheels are the same as any good aftermarket wheels because they just farm out to BBS or Ronal for instance to produce their wheels. They simply spec them out to fit the calipers for instance.
The wheel industry had changed so much over the last twenty years. Yea HRE was the best custom house back when BBS was the gold standard. I've owned a lot of HRE product. It's not easy to say this brand is better than that nowadays because of how the industry works in modern times. MHT/DUB I think it is, is a conglomerate that umbrellas about 20 different wheel companies under many different names including Rotiform. THERE IS ONE CENTRAL PLACE THEY MILL ALL THE FORGED STUFF.
I have had a wheel failure on a track before ... not fun. I've also had cheaply made cast wheels crack without any undue stress put on them.
are cast wheels suitable for the street? absolutely ... however, i would pick a wheel from a manufacturer that has a solid reputation for QC and construction methods.
Not cheap and I don't know if they would clear the ceramics:
20" PUR 4OUR Forged Staggered Wheels Pirelli Tires 2016 Jaguar F Type R Coupe | eBay
In real world city driving situations, what makes the most sense?
Some options:
CCW: Home - CCWheel
Not as flashy as HRE, but they are good wheels.
Lots of flashy options here for a forged wheel:
http://www.wheelpros.com/default.cfm
CCW: Home - CCWheel
Im not saying it could never happen but the more likely scenario is you hit a pothole and dent a front. When this happens, look to shell out about a grand to repair the forged. The cast, you buy another.
wheels are a safety item, it's not worth going cheap on.
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/636x424/192be3bsloeoyjpg_4c8b5f94dc85a8f01bfdf38ef5470d163034b472.jpg)
If you think that could happen in a normal circumstance, I would agree with you wholeheartedly. Further, if that type of failure could be possible, the company should be sued, a cease and assist levied, and certainly you should be naming the brand, model and circumstances from every pulpit you get.
To treat this like a mere by-product of selecting a wheel that wasn't high enough quality for your application is a disservice to the public if indeed this particular wheel failed under a regular circumstance.
First off it would be great to know did an accident cause the wheel to fail or did the wheel failure create the accident. Let's start here. I see a lot of edge grinding as if the wheel hit a guard rail, curb or median.
And believe me, I know certain cheap Chinese wheels are garbage. I'm far from denying that. The real solution is our feedback. If you bought a set of wheels that were garbage, then I'm al for avoiding that wheel, type, or brand altogether but at what point can we say, OK this wheel is good enough. I will assure you HRE's have failed at some point.
Burt Gummer (07-13-2016)
