Dealer oops during 3 year service
I brought my AWD S in for its 32k service this morning. Everything was going well until they went for the transmission/differential fluid change. According to the techs, two nuts that are welded to the chassis may have broken loose at the transmission mount so they can’t remove the bolts that keep the guard on. And even if they break the bolts off, they have to figure out how to put it back on. Looks like they will need to get their shop foreman and Jag HQ for the fix. Their ftype techs only work Tuesday thru Saturday, so I’ve got an FPace till Tuesday at the earliest.
Not blaming the dealership, I’ve had my issues with bolts breaking while working on my cars.
Does anyone know which bolts could be giving this trouble?
See this thread from uk forum...
https://www.ftypeforums.co.uk/viewto...e3ae5daae56a17
It appears to be the AWD transfer box.
From an update posted by the OP in the thread linked in post #3 here:
"To update this after my conversation with their Service Manager today. What I was told by the Service Advisor was fundamentally incorrect. It was the Transfer Box fluid that was being changed as part of the service schedule and in order to do that the gearbox cross member needs to be removed. It was a captive nut within the chassis that came loose and necessitated the specialist works."
Lots of initial confusion in that thread that the OP was talking about the simple plastic undertray (the rear one) and two of the four bolts which hold that tray on. I have removed that tray at least three times (it needs to come off to access the sump plug) and never had a problem with "captive nuts" so I couldn't figure out what they were talking about and I put it down to some difference in the way the tray was attached on an AWD compared to a RWD.
But it's not the tray at all, it's a gearbox cross member and the captive nuts on the top of it.
sorry to revive an old thread however I have my V6S AWD at my mechanic (so not an original Jaguar dealership as car is out of warranty) and he is having exactly the same issue while undergoing the transfer box oil change.
@Joseph do you by any chance happen to have any pictures from that repair we could figure the fix from?
It seems like a pain in the *** issue and very poor engineering on the Jaguar side, I don`t even want to imagine the price for the repair Jag would call me with for something like this had it been them doing this oil change...
Snowii: It sounds like the problem I had a couple of years ago where the castle nuts break loose in the body and you are unable to remove the crossmember in order to drain the fluid. The good news is, you do not have to remove it in order to change the fluid. Here is a write up with pictures I did. Show this to your mechanic. Good Luck!
https://www.jaguarforums.com/forum/f...-v-8-a-240871/
doriel
10-11-2016 08:12 PM
himble12345
02-20-2015 02:10 PM
Jaguarnewbie2011
11-27-2010 09:39 AM
