Dealers OK with VAP Tune
After reading the extensive information on the VAP Tune (thank you all) I have have decided I'd like to get the ECU tune and maybe add the lower pulley at a later date (as well as a short shifter). I have a V6 base manual coupe so 76 more BHP seems obvious. If I understand correctly there is no issue with California smog and the ability to flash back to factory tune is a bonus.
However, being thorough that I tend to be, I was going to approach my Jag dealership's service manager to ask about their position on whether this tune voids the warranty. A number of owners here have dealers that are apparently aware of the installation of the tune (and maybe other mods) and seemingly indicated it would not void their warranty. My question is if you could advise which dealers are ok with the tune so in the event my local dealer (Monterey, CA) balks I can intelligently respond that some of their peers are ok with the tune.
DPelletier (09-26-2017)
The simple answer to this question every time on every forum is that if you tune the car, be prepared to pay any related repair bills. What related is will always be a source of debate. Sometimes you might even get a good will repair on something that is related. However, no one can honestly tell you that if you blow your engine JLR will cover it. They won't 99% of the time.
The following 2 users liked this post by caviarjag:
Burt Gummer (09-25-2017),
JagRag (09-26-2017)
However, I can say short of blowing your engine the dealer likely will not be aware of a tune. I recently had some very major engine repairs done under warranty (which weren't the fault of my tune/pulley) and no mention was made of anything; everything was covered under warranty. Once Jaguar N/A is involved however, its a completely different story.
That being said, you must be prepared to buy/fix an engine if you install a modification to it.
The following 2 users liked this post by Stohlen:
DPelletier (09-26-2017),
Jim F (09-25-2017)
This.
And this.
And this.
This.
And this.
And this.
Dave
SinF (09-26-2017)
Received 10,871 Likes
It's certainly ultimately to JLR to approve or reject *paying* the warranty claims. That comes after the work is done and the car is down the road. If JLR doesn't pay the dealer is left holding the bag.
No informed USA dealer service manager would tell you the warranty would be *voided outright*. Jaguar can't do that based modifications.
An informed SM would tell you that problems provably arising due to owner modifications wouldn't be covered. IOW, if your (let's say) power seat motor fails Jaguar cannot deny warranty coverage unless they can prove the failure was related to tune.
Received 2,263 Likes
But seems largely focussed on the UK market with respect to diesel engined vehicles, (DPF) of which so far, I don't believe there is an F-Type model.
It also may have no bearing on how Jaguar USA regards warranty issues.
