Dealers OK with VAP Tune
Received 2,263 Likes
Received 3,226 Likes
I had a diesel XF (2010 XFS) and I fitted a tuning chip to it and I very nearly gutted/removed the DPF but upgraded to an XFR before I did so. The DPF is the Devil's own invention, it clogs up at the drop of a hat and causes no end of problems, so of course many Jag diesel owners (S type, XF, XJ) looked to remove the damnable thing and/or to tune the motor for more power and especially more torque. Removing the DPF necessitates some fiddling with the ECU software to fool it into believing the DPF is still there, otherwise you get CELs and Restricted Performance mode. The 3.0 twin turbo V6 diesel is easily and cheaply tuned to 700 Nm of torque or more with very little downside, so like me many did so. The bulletin is obviously directed at diesels not petrols, but that said the same principles would apply across the board, model range and planet.
I can't imagine that the official policy in the US would be much different.
I suspect it is specifically mentioning diesels because it seems to be very common for those to get an upgrade in the UK compared to petrol models.
Received 10,916 Likes
From a previous thread regarding tunes and warranty coverage we gleaned this official statement from Jaguar USA.....
".....alteration or modification of the vehicle, including changes to the body, chassis, or any tampering with the vehicle, tampering with the emissions systems or with other parts that affect these systems may impact coverage of your factory warranty for those items impacted."
And from the bulletin mentioned in this thread......
".....calibration files into the Engine Control Modules, or through add-on hardware. Other power upgrades may also
be available, and in all cases, warranty responsibility on any affected component does not lie with Jaguar Land
Rover."
Same policy, in essence, but notice the difference.
#28
No doubt.
And you can bet that every other car builder has similar policies and statements. I've never come across one who didn't.
#30
#31
If there ever is an issue with the engine or possibly the sensors that the engine uses data from(i.e. oxygen sensor), the dealer may not warranty depending on the place. With a tune in the PCM, they throw a code for aftermarket tuning. Saw this once with a customer car that needed an engine. Jag declined warranty replacement due to code that stated aftermarket tune.
#32
#33
While dealer might cover up/look the other way a tune for repeat customer that purchased multiple new vehicles from them, it is unlikely to be true for someone that purchased a used car from a third-party and is now bringing it to them.
#34
Problem is to put in a new engine under Jaguar warranty, you need to upload certain documents and read of codes to get proper authorization for replacement. If they see that code for aftermarket tune, its an automatic rejection.
SinF (01-06-2021)
#36
This has been discussed many times but I hope I can clarify this to all,,
1. The dealer has no issue of you tuning your car. If you tune your car then it breaks the dealer will happily repair it under warranty if JLR don't interfere/care. If a dealer declines your warranty work they lose the labor rate they are charging JLR. It is in your dealer's interest not to deny any warranty claim tuned or not because they get paid if they do the repair whether it is under warranty or outta your pocket.
2. Personally my service manager said "I don't care if you tune your XFR, matter of fact let me know if it is any good so I can tune my XJR (his is out of warranty). However if something goes wrong make sure you remove the tune before you bring it in. If one of my technicians flags it accidentally (puts it in the repair job card) that ecu has been modified JLR will most likely deny the claim if it is power-train related.
3. My service manager also mentioned that usually in every 10 failures of the same engine/model JLR will ask us to connect us online to the vehicle for diagnosis or send us a JLR engineer to further inspect. Usually JLR engineers will try to deny a claim if it has been modified (AND IT IS THEIR RIGHT TO DO SO). He said that JLR would trust our diagnosis and most of the time if it has been a common failure like a water pump, they will just ask us to send the report and approve the repair/warranty claim instantly.
4. Last thing my service manager said that you will find some service managers, advisors, or technicians decline a warranty claim if you are tuned even though if JLR didn't decline it. Reason being if they see the tune or modification and they turn a blind eye but then JLR suddenly asks for further inspection by connecting the engineers to the vehicle online or send a JLR engineer and they found out the dealership overlooked the tune, the dealership will loose their credibility and/or fined for doing so as they are considered cheating the system. Even though it is highly unlikely the modification didn't cause the failure but they (JLR) want any exit out of it if they can.
5. 1+1=2 it is as simple as that. If you tune your car you risk getting screwed if something goes wrong. It is their right to deny a claim if any modification is done what so ever other than factory settings unless approved by JLR prior to installation. With that being said. It all depends on your dealer and how far they are willing to help you out when **** happens. Keep in mind even if they go all out on helping you out JLR has the final say so it doesn't matter. My service manager promised me that he will do everything that he can to help me out if something were to go wrong and I need a warranty claim even though my vehicle is modified since I have a 12+ years of a relationship with his service senter and 5 vehicles but really what is his word? He could pass away the next week or change jobs or get fired or retired and then what? basically Keep in mind if you modify = you could be denied warranty
Best of luck and sorry for the long reply was just hoping I'd clarify as much as I could.
AlexJag
12-10-2016 05:00 PM
