Death Machine
Death Machine
I have a 2015 RWD R coupe with 15,000 miles on it...always fun, a little wild but controllable....but, it almost killed me the other day and I'm freaked out because there is little rhyme or reason for the event....
I was driving on a blacktop highway at about 60 mph, in the rain and I wanted to show a friend how the exhaust baffles open up at higher RPMs even when the active exhaust is off...
I was going dead straight...shifted from 6th gear to 4th, and the car pitched into a viscous high speed spin next to a concrete divider...luckily with good skill and God, I carefully corrected the car from spinning and then pitching in the opposite direction after correction....it scared the $&@@ out of me because it never did that to me before.
I was in normal mode....not dynamic and I didn't hydroplane on water....
The funny thing is that the car felt loose the entire day but I don't know why... Could it be the tires? It appears that I have even tread all throughout....is there a point on the P zeros that they simply are not functional in the rain, even with tread?
I've gone to many high performance driving schools and the last time I did the R performance academy, it was in the pouring rain...no problems whatsoever.
I used to think AWD was kinda dumb on this car, I'm rethinking it totally....
Any input would be helpful.
buickfunnycar.com (10-04-2015)
I obviously misjudged the traction...but I was shocked how bad it was and how out of control the car was....it never did that to me ....
I drove the car hard on the track at Monticello in the pouring rain in dynamic mode and had nothing close to that happening.....
it was really bizarre...
I will add that today my TPMS told me all 4 tires were low (temperature change) ...they were at 26 psi instead of 36. I filled them up and we'll see if that makes a difference.
I don't care whether they were PSS or PZeros, the result would have been the same. What you did was worse than burying the throttle under the same conditions, because you created a sudden braking situation with the downshift, while breaking the rear tires loose.
The car is not the "death machine" in this case.
The following 3 users liked this post by Foosh:
How many miles were on the tires and how warm was it at the track day? 15,000 miles is a lot on the Pirellis, especially if accumulated over lots of short trips. They tend to degrade with heat cycles so even if they have tread left they do not offer a lot of grip when well-used. A new set will bring back the performance you remember, at least when warm.
I'd suggest (at least for now) changing out the tires for some performance all seasons that are more suited to the temps/conditions you're likely to encounter at least in the next 6 months in NJ. Given your mileage of 15K it sounds like you're driving the car a fair amount, and unlikely to park it over the winter.
Summer tires (esp worn out ones) just aren't going to cut it, esp on the R.
I don't know what the current 'best' all season tire is - maybe a Michelin or a Continental Extreme Contact DWS?
Received 2,263 Likes
I researched the best rated Ultra-High Performance All-Season tire on TireRack.com and the overwhelming favorite - at #1, with far and away the most miles logged - was the Continental Extreme Contact DWS which I've purchased for driving this winter, in Maine. While quite a differ car, I also have them on my Audi A8L and they're superb! I'm quite curious to see how well they'll perform on my F-Type and looking forward to pushing the limits a bit more this winter (while I sit here on Isla Mujeres, Mexico with the Caribbean Ocean as my back-drop). In other words, winter tires - any tires - are the last thing on my mind.
Everybody's responses have been great, but I do think the question remains... Do you really think a car should almost spin out at highway speeds in the rain during 50 degree weather just for being downshifted 2 gears on an 8 speed gearbox (closer ratios)????
My XFR didn't ever threaten my safety like that even when I would drive it like an idiot in bad weather with summer tires.....
Either there is something dynamically amiss with the F-Type or the P zeros suck that bad....(I think it may be a combo of both)
Obviously your action of downshifting caused enough drag on the tires that they broke traction. Doing so on wet pavement was just asking for trouble.
1) In the rain, at highway speeds, a driver suddenly executes a 2-gear down-shift which introduces a braking action that instantly shifts the weight balance of the car forward. The rear wheels are spun up because of the sudden rpm increase, so the tires lose all traction and are spinning on the wet pavement, introducing a sideways movement, with a now suddenly unloaded rear-end. The law of conservation of momentum predicts that the now unloaded, traction-less rear-end is going to keep going forward, which it does with spinning rear wheels pushing it sideways, but the front-end is more planted = spin.
2) In the rain, at highway speeds the driver suddenly buries the throttle which does not introduce the braking force and instantly shifts the weight balance of the car rearward or keeps it more neutral. Rear tires lose traction on wet pavement, and car may wiggle a bit, but maintains forward motion without spinning.
Professional drivers continually reinforce the importance of keeping a car as balanced as possible under all conditions and avoid abrupt weight transfers, or in other words, "don't upset the car." All weight transitions should be very smooth (e.g. not sudden). Cool tires on wet pavement make those principles even more important because loss of control can happen much quicker and exceed the stability control system's capability to correct for it before loss of control.
The following 5 users liked this post by Foosh:
FrickenJag (10-05-2015),
MarcusXFR (10-05-2015),
Mikey (10-04-2015),
TR64ever (10-05-2015),
TXJagR (10-04-2015)
Have you been to a professional driving school like the BMW 2 Day M School?
If not I would highly recommend it. I learned a lot about driving in the wet.
If the downshift was initiated just prior to the intended application of throttle, the snap spin was likely initiated before he made it to the throttle. Since everything happened so quickly, it would be impossible to accurately reconstruct one's actions through the adrenalin fog.
