Decelerating lurch at low speed / rpm
Old 12-04-2017, 02:51 PM
Nati's Avatar
Default Decelerating lurch at low speed / rpm
Ok gang, got another one that I'm not sure if I should be concerned about or not. When in stop/go traffic does anyone get a pretty impressive lurch as soon as you let off the gas? We are talking from low speeds here, 15 mph or so. For a while I've thought the transmission just sucks at picking a low gear and was downshifting, but today I found that it does it even in manual shift mode with first gear selected. Is this a symptom of a mechanical problem or just an idiosyncrasy within the spectrum of normal?
Old 12-04-2017, 03:01 PM
DJS's Avatar
DJS
DJS is online now
Received 2,148 Likes on 1,438 Posts
Hmmm. I've found the F-type to be remarkably smooth when decelerating in lower gears, or when lifting off - no lugging at all. Does it matter whether it's in dynamic? At low revs, the torque converter should be pretty slippy, and I wouldn't expect any kind of jerk. (Cue Seinfeld: The jerk store called...)
Nati (12-04-2017)
Old 12-04-2017, 07:22 PM
Nati's Avatar
Dave,
Noticing this in both performance modes, normal and dynamic.
Old 12-04-2017, 08:23 PM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
Could be a number of things:
1. Bad universal
2. Bad CV joint
3. Excessive lash/wear in the diff.,
4. Tranny issue.
Does it make any kind of clunking or clanking sound, or is it just a lurch sans sound effects?
Old 12-04-2017, 08:24 PM
StepOut's Avatar
I notice this too, 2016 F-Type R AWD, at very low speeds, stop and go, slight clunk like slack being taken up in drive train.
Old 12-04-2017, 10:08 PM
Nati's Avatar
Yeah, perhaps a slight clunk - I'd agree with that.
Old 12-05-2017, 08:10 AM
Dogbreath!'s Avatar
I don't have any of that. Perfectly smooth, just as it should be.
Old 12-05-2017, 08:52 AM
Tel's Avatar
Tel
Tel is offline
Nope, all good in the hood with RWD.
Old 12-05-2017, 11:18 AM
DPelletier's Avatar
Mine doesn't do it either.....looking at the responses, I wonder if it's an AWD thing?
Dave
Old 12-05-2017, 12:38 PM
F-Toype's Avatar
I have AWD, and while I wouldn't describe it as a "lurch", I do feel a surge when coasting "downhill" leaving parking garage (~15 MPH). One thing I have noticed recently is that there is a hard engagement/clunk of transmission when shifting from Park to Reverse. I don't remember it being like that at the beginning (current mileage = 6K mi). I will be having it looked at by dealer.
Old 12-05-2017, 09:10 PM
Unhingd's Avatar
There is a TSB and software update for that.
F-Toype (12-06-2017)
Old 01-11-2018, 05:42 AM
Totti's Avatar
I had the same issue as you. I have a 2016 F-Type R AWD (13,000 miles) and I used to have two issues:
- Whenever I release the gas pedal and press it again in speeds lower than 30 mph, i used to feel a slight bump/lurch coming from the back of the car.
- when i switch the gear to R, i can hear and feel a slight/faint bump from the gearbox. It doesn't happen on D. This always happens, doesn't matter if the car is cold or warmed up.
I kept the car with the dealer for three weeks to resolve these issues. They updated the gearbox software to the latest available one, but that did not resolve the issues. Post that, they consulted Jaguar and they were advise to replace the rear differential under warranty. I received the car after the changes were completed, but the two issues are still there. I am wondering if these issues are normal, or should I be worried.
I drove my friend's 2017 range rover that I believe has the same gearbox, and i was able to feel that bump when pressing the gas pedal.
Old 01-11-2018, 06:17 AM
Unhingd's Avatar
It's not in the gear box. It's excessive lash in the differential gears. All the F-Types I have driven have this issue.
Old 01-11-2018, 09:06 AM
alphakinase's Avatar
In my XE (RWD), there is a distinct feeling of something engaging/disengaging, occuring probably around 5mph, when you are coasting down to a stop. I've always assumend this was just the torque converter going from locked mode to slippery.
It's not the gears changing, because it will occur if you are in S mode in 1st gear.
Old 01-12-2018, 10:05 AM
watson6505's Avatar
the only time I feel a 'lurch' in my v6s is when I am in paddle shift mode and take first or second gear to the upper rpms and let off the gas. That's just transferring from acceleration mode to deceleration mode. I assume this is normal
Imagine you are in first gear and you are trying to get the crackles and snorts, this is when this happens
Old 01-15-2018, 12:08 PM
Totti's Avatar
Thanks all for your replies. It usually happens in low speeds and lower gears.
What about the Reverse gear slight/faint bump, are you guys having the same symptom in your cars?
Old 01-15-2018, 01:21 PM
Nati's Avatar
I get a clunky engagement into reverse about 20% of the time. Why it isn't every time I couldn't say. I ignore it.
Old 01-15-2018, 01:58 PM
ShaunPA's Avatar
i have a similar lurch experience but it's only on the 3-2 downshift when braking/slowing if i let the computer do it.
Old 01-15-2018, 04:31 PM
amcdonal86's Avatar
Just a thought, could it be fuel sloshing in the tank?
Old 01-15-2018, 05:10 PM
ShaunPA's Avatar
its definitely mechanical. either diff or gearbox.
