Deciding between VAP and H&R lowering springs
I have a 2016 F Type R and am trying to decide between VAP or H&R lowering springs. I like the look of the H&R springs better but am worried about scraping on the many speed humps in my neighborhood. Also would like to know if there are any handling or ride quality differences between the two sets. I also plan on adding 15mm wheel spacers
i didnt need to get my suspension "tuned", what ever that means.
skizot (11-15-2022)
Sidebar: Google works wonders for learning new things, if one cares for it lol
Received 3,259 Likes
I and many others have reported "pogoing" with the VAP springs which apparently doesn't happen with the H&R springs.
By "pogoing" I mean bouncing up and down a bit when hitting a dip in the road at speed, the car seems to literally bounce up and down before settling. There is one stretch of road I used to go over regularly with three or four dips followed by rises where it was very noticeable at only 60 mph or so.
This has been explained as due to the rebound rate of the shocks/dampers now being out of whack with the springs.
Also with the car being a little lower on the H&R springs the centre of gravity should be lower and therefore the handling at 10 10ths should be fractionally better, but that is just supposition on my part.
The following 3 users liked this post by OzXFR:
For the rest, I have H&R springs and they work great with the stock damping, no oscillation, good body control, inproved feedback through the chassis and steering. Oh and they look great. Scraping - not terrible, you have to be careful with sudden grade increases like a steep driveway or some intersections but not that big of a deal.
Nope. First, terrible analogy, and you should NOT run any pulley upgrade without a tune. But I digress. How exactly do you plan to fine tune compression/rebound rates on the stock dampers? They have two modes from the factory.
I'm not aware of multiple series made for the F-Type, but maybe I just haven't seen them. The H&Rs on my car dropped it a bit over an inch. Also have 15mm spacers (depending on rims you may have to trim your studs for those) and clearance with the fender lip is fine. I believe I got them on sale for mid $300's. Keep in mind, there may be different part numbers for AWD vs. RWD, and definitely different depending on whether you have a V6 or V8. Mine is a V8R RWD - just make sure you get the right set of springs. Also you will want to get an alignment done after installation - mine wasn't too far off after lowering, but it's also an opportunity to tweak your camber and toe to your desired specs (if you want). I went with more negative camber and very slight toe out to improve response at the front end (caveat if you do a lot of highway driving with rusty roads the nose may be more slightly inclined to tram, minor tradeoffs, nothing major). Ymmv.
Looks only. When you lower the car it amplifies the "tucked" look of the stock rims/offsets. Those spacers bring them to flush with the fenders.
I think it comes down to what do you want from your car. VAP are great springs, however they give a more raked look (back sit's higher then front), which many who have VAP do not like. H&R (which I have) makes the car more balanced and while lower than other springs for this platform, for me, sits and drives just right. I also have always lowered every car I have ever owned, so I am used a more sporty ride and lower stance. Ultimate adjustability would be to go with a set of KW coilovers, however you were asking about springs. I have been riding on them since 2019, love them. It is phenomenal. Better corner handling, better 1/4 mile traction as less suspension travel from a dig, better looks and while definitely need to adjust driving style over bump/inclines/etc that is a small price to pay. As for any after installation "tuning" that is all bullshit. No such thing. Car already has ability to adjust dampening based on mode (sport vs. normal) and you can turn this off if you desire inside the settings if you prefer normal mode, even when in sport. For me, I prefer full sport mode (including suspenion) when I turn it on, but also on occasion could tweak for the right situation to turn on suspension sport mode with all other sport modes turned off, but not sure why you would want that? Nevertheless, H&R to me, is the best balance of ride, looks and performance of all the options currently available.
https://www.evasivemotorsports.com/s...ble-qq6-16-20/
