The Definitive Android 10.25” Retrofit Thread
#61
#62
In the one install video that we have seen, the system is plug in. No cutting or splicing involved. So that would make it completely reversible.
usgpru27 (11-13-2018)
#63
#66
Received 3,209 Likes
#69
#70
The following 4 users liked this post by frostysauce:
#71
It would be nice if we can easily tell which screen we have without a dismantle. A bit of a check list which spits out an answer.
#72
Apparently, Paul, we were both sending them emails and they were mixed up a bit
I was waiting on a quote from Jenny or Robin, but I will gladly join the group buy if it comes close to the $800 mark.
So, to clarify once again: there are only 2 versions possible? Bosch or Harman. Is there a sure way to know which one you have, other than taking it apart?
I'll drop my seperate conversation and go with a group buy.
I don't like the dongle that you have to plug into for CarPlay, but there are WiFi CarPlay plugins out there.
What version of Android is it really? Seen so many different versions quoted. Merryway web site says 4.x, I've seen 6.x and 7.x. 4.x is pretty old, being ended in 2010.
#73
I was talking to Robin, and I was quoted $1200. I spotted the previously mentioned $880 one on aliexpress, it's not for f-type.
#74
#76
This is where things get interesting...
I did pose this question, and it sounds like these units aren't even available for the F-Type, they just list them as a product. They are very similar to other retrofits from Merryway, for the XF for example, but from what I read between the lines is that they haven't even officially made this yet, because no one has ordered one. Jenny said now that I have placed the order, they will go ahead with making one. This came as a bit of a surprise for me, as I thought these were on-the-shelf units, but that doesn't sound to be the case.
To be honest though, I'm not really surprised. I've worked with manufacturers in China directly before and it's very smoke and mirrors what is real and what is not. I do believe that they have done this for an F-Type before - it's possible they just haven't sold any yet, or they've retrofitted a model which is identical, just not on the F-Type directly. I'm really not 100% crystal clear, but the money is gone and the PO is cut and it sounds like Merryway is very interested in making this group buy possible around our price point. Oftentimes there is a single manufacturer, and a ton of resellers and re-branding going on - so i'm attempting to get a bit closer to the source here and it sounds like Merryway is it, or at least works directly with whoever is producing these.
Time will reveal all secrets
#77
#78
I think you should be relatively safe because I suspect the manufacturing is more to do with mounting and screen bezel. The core unit for the Bosch system is the same across JLR cars, so I am expecting the electronics to be fully compatible. For those with the NLI - Harman system I think things are a bit more interesting because I haven't seen any demos or installs of that version !
The screens on these units do much less, as the processing is done in a separate unit, the Audio Head Unit under the centre arm rest. It is literally one cable into the back of these screens. Looking forward to the write up though to understand what the system is like in reality. At least with the current system you get in and go. Will be interested to hear how close it is with the new system, or whether you have mess around with hotspot connectivity each time you get in.
