The Definitive Android 10.25 Retrofit Thread
#142
#143
#145
The last attempt and Carnage.... https://youtu.be/4o9MbG4o9h8
my quick diagnosis https://youtu.be/xypnFGjQLuo
Playlist https://www.youtube.com/playlist?lis...Bxz28mwpEYYQbp
#146
#147
I think here the bigger question is why it has destroyed 2 ribbon cables. It looks like too much current is being drawn or it is shorting. hopefully the cable burning out is protecting the daughter boards from the original. A new screen is not cheap.once again much respect for Rick leading the way.
#148
#149
#150
#151
Once frostysauce starts testing his unit, we will know if this is just a freak occurrence or an actual design flaw.
#152
Once you get a good ribbon cable, you should try plugging all the OEM equipment back together again to see if it still works.
#153
#154
#156
#157
Hey guys,
I wound up doing the install today. Good news is that the unit powered up. Bad news, is that I am not getting any sound or any feed from the backup camera. This looks to be just because of the lack of instructions, as with the monstrous wiring harness and no instructions, i'm not sure which things should be proxied and which things should be directly connected. The manual that was provided is purely a user guide and does not show how to plug in the units connections. I am still working on that, and once I figure out the way everything should be plugged up I will go ahead and do my install video. In the meantime, I am uploading the video for the headunit removal, and the integration of the headunit in the merryway chassis right now and those should be up shortly.
If anyone has any better pictures of what the cables connect to, and where they connect to on the harness, that would be very helpful. I've watched one of the videos in this thread where he is inserting the unit into an F-Type, but it skips some parts and then all of the sudden everything is plugged in and he's starting it up. I clearly see that the video component cable should be plugged into something, but I am just not sure what.
The following 3 users liked this post by frostysauce:
#158
The following 13 users liked this post by frostysauce:
355rockit (11-29-2018),
62jeff (11-29-2018),
death1ord (12-05-2018),
domino_z (11-29-2018),
evilftypedw (11-29-2018),
and 8 others liked this post.
#159
Not sure if this is the same Jenny that some of us have been talking to, but this video appears to be from her own YouTube account:
https://www.youtube.com/watch?v=vOQscP66y3Q
I'm currently unable to get the sound to work, and i'm not quite sure why that is - also, getting the backup cam working was a bit of a challenge but I figured it out (There are some supplied connectors). But, I did test and the backup cam comes on as soon as you put the car in reverse.
I have not seen anything that indicates the OEM screens will be available, this means no dynamic screen, no climate control screen, etc (Those are the only two things I used the stock HU for anyways)
Working with Jenny to figure out why I am unable to get any sound out of the system. I imagine it's because there are a ton of connectors and I am either missing one connection, or have it plugged in incorrectly (there are a few duplicate male/female connectors).
I have an install video and some initial startup footage, but because I wasn't able to get everything working properly I am waiting on publishing that. And install video is no good if I get it all wrong
The following 5 users liked this post by frostysauce:
Paul champagne (11-29-2018),
rexus31 (11-29-2018),
tscjoki (11-30-2018)
#160
