Diagnosis Jag - Injector failure?
Old 06-06-2019, 02:09 PM
FType17's Avatar
Originally Posted by Itismejoshy
not really, have 2 pumps on the way (and 4 injectors/tool). Spent the evening setting up SDD on a new burner laptop (my old SDD was on a painfull almost unusable slow laptop) in hopes of verifying this with the datalogger and running any "test" procedures it recommends. i also believe i have had an injector issue on the pass side of the vehicle for some time, as my pass side factory cat (when it was still on the f-type) was throwing "cat below efficiency" codes that JLR shrugged off after some major work, was told it was a bad coil and it was replaced (except the new coil was on the drivers side after some investigation)....so could it be that an intermittent sticking open injector was pushing the pumps hard all the time to keep up(only a theory?) eventually leading to failure of the pump? on the plus side i just got my latest blackstone report and its perfect like all the others. i just don't understand how i am at my 3rd set of HPFP in less then 40k. i have run race fuel ( but even that only US 103) and less then a handful of times...always 93.
I forgot the cat code (420/430) but it is common and usually replaced by the dealer under warranty without much arguing.
Keep in mind that the pumps have lifetime warranty.
Unhingd (06-07-2019)
Old 06-07-2019, 07:08 AM
Itismejoshy's Avatar
so i don't think its the HPFPs at this point....going to setup SDD for misfire counts and see if i can identify a cylinder that is "worse" then the others and pull the plug/coil for inspection. still could be an injector.
(Sorry the video is hard to see)
Old 06-07-2019, 07:17 AM
Think they will let me bring my cat in (out of the f-type) and demand a replacement lol? i didn't know the pumps had a lifetime warranty, JLR told me they would warranty then for a year, been little over a year.
also cylinder#2 seems to be the majority of my issues so i will be digging into that later.
Old 06-07-2019, 12:49 PM
FType17's Avatar
https://www.boschautoparts.com/en/support/fp-warranty
The dealer would not replace your cats if you just bring in the parts
Old 06-07-2019, 01:54 PM
FType17's Avatar
Injectors are also lifetime warranty.... and if you buy, get a Bosch one directly, it's 50% off than the dealer
The following 2 users liked this post by FType17:
Itismejoshy (06-07-2019), Paul_59 (06-08-2019)
Dustin Moorman
01-10-2023 08:42 PM
dbeck84
02-20-2019 11:51 PM
JimC64
12-27-2013 09:38 AM
loaks111
07-10-2008 10:18 AM
ShaguarNYC
05-31-2008 04:00 PM
Quick Reply: Diagnosis Jag - Injector failure?
