dip mirrors. Don't dip
It (right mirror only) undips if you go more than 5MPH in reverse, but I doubt that's the issue. When it's in the dipped position, you can adjust its position, which will be remembered next time it dips. Perhaps the dipped position is adjusted nearly the same as the undipped?
With auto-dip on, put it in reverse, adjust the right mirror, then take it out of reverse. See if it moves.
called jag service. waited for them to call me back. went back and reread the Manuel...discovered by pushing the right and left mirror buttons together the mirrors retracted...and guess what? after doing this once my mirror now dips. Hallelujah. Service calls me back at the end of the day...(busy with a customer, for 8 hours.) and tells me he's not sure if my car has dip mirrors (he has my build sheet), but if i did retracting the mirrors would cause them to reset and then they might work. Thanks.
Richard_gib
09-12-2015 07:08 PM
