disconect start /stop
I have seen threads for the 14-15s and it involved simply pulling a plug. I do not have such a plug on my 16 so I am open to ideas myself
i had this feature on my Denali and bought an auto stop eliminator. Installed the harness after removing a significant part of the dash/console. Well worth it to me though. Sadly I do not see that available for our cars.
Received 3,208 Likes
On the 14-15 with the dual battery set up you disconnect the earth/ground lead from the negative terminal of the secondary/small battery from where it bolts to the floor of the trunk/boot, on the 16 and up (single battery only) you pull a plug in the trunk/boot, there is a thread showing exactly which plug and where somewhere around here.
Edit - found it: https://www.jaguarforums.com/forum/f...attery-146010/
The following 2 users liked this post by powerhouse:
Iticip (07-03-2022),
Thunderjet Racing (05-16-2023)
Doesn't help the OP with the coupe, but I understand the SmartTop accessory controls can let you disable the S/S as well.
https://smarttop.uk/
Sorry, other way around.
Portlander (05-16-2023)
Disconnected the plug which eliminated the auto start/stop feature as it did in my previous F-Types. However, the yellow light remains constant unless I push the button which would be no different than if I kept the feature connected as far as physical exertion.
So I covered the light with a slender piece of electrical tape and all is fine. Dwight Frye had the same issue so maybe the 2021 and newer vehicles are stuck with a continuous indicator light.
