Disconnecting Battery
Received 3,209 Likes
Three pages about "Vehicle Battery" in the Owner Handbook but they are all about safety/warnings and how to connect and disconnect jumper leads or charging leads.
All it says about disconnecting the battery itself is this extremely unhelpful text:
"REPLACING THE VEHICLE BATTERY
Battery disconnection, removal, and
replacement, should only be carried out
by qualified personnel. Consult your
Dealer/Authorised Repairer."
The Workshop Manual has a page on disconnecting and reconnecting the battery, see attached.
Put simply, when disconnecting the battery undo and disconnect the ground cable first (it runs from the negative terminal to an earthing point) and then disconnect the positive lead, then reverse this when reconnecting the battery - positive lead on first, earth lead on last. Obviously when disconnecting the battery make sure the engine and ignition are OFF!
Then after reconnecting the battery cables idle the car for two minutes to allow the ECM (Engine Control Module) to relearn the idle values, then put it in D with foot on the brake and idle for another two minutes, then drive for 5 miles / 8 km of varied driving to complete the ECM learning process.
I'm not entirely sure all this foo-fora is necessary, I have disconnected the battery a few times now by doing nothing more than undoing the earth lead connection at the earthing point and never had a single problem with anything.
Paul_59 (09-25-2019)
Based on your experience I would say it is not a problem!
I haven't done as many "resets" as Lance but I never once even considered the EPB when doing so and never had any issues with it. I too have had to reset the windows, and that's something that can be frustrating. Once you get the proper incantation though it works every time. I can't remember the details, but they're quite specific.
At least that is how it has been for me every single time!
Hmmm. My notes don't include the proper incantation. It's here on the forum somewhere. It seems I didn't update my notes after the "why doesn't this work!" episode.
My recollection is that ignition on doesn't work, but on and engine running does. Lemme check my notes ...
"WINDOW RESET
The windows will need to be reset if the battery is disconnected, becomes discharged, or the power supply is interrupted.
Once the power supply is restored, reset the windows as follows:
1. Close the window fully.
2. Release the switch, then lift it to the close
position and hold for 2 seconds.
3. Open the window fully.
4. Release the switch, then push it to the open
5. Lift and release the switch to operate the
one-touch function.
6. Repeat the procedure on each window."
Some have found this works with just the ignition on, others have found that it only works with the engine started but the car not moving, but I have found every single time (at least four times now) that it only works while the car is moving (ie I am driving).
This is important. The community awaits your report (probably at the bar).
Bbeck1118 (01-21-2022)
Interesting, but we're not covering all possible permutations. The missing data point in your experimentation is whether it has to be *you* driving. Next time, have a different driver try the procedure.
Even then she is odds on to tell me where I can stick my instructions and say "you can't possibly expect me to do that while I am driving, it's already hard enough to keep this car under control even at 20 km/h under the posted limit."
Carbuff2 (03-09-2020)
