I can barely find the information abat out Jag cause there are few owners of it here in Korea.
Can anyone let me know it I'm right on changing my stock diffuser into disign pack?
This one is mine.
And this one is currently what i'm trying to go.
As you see guys,(from google)
Mine has double color , one in red another in white.
I will order 2 fog lights and diffuser on ebay.
And then it will fits?
And for the lights, My reverse lamp is halogen which looks bad Thus I'd like to change it into LED.
Is it possible? if it is, who can recommand the product for it without error code?
The lights in the Design Pack rear valance (your second pic) are combined reversing and fog lights - two separate LEDs one white one red.
As you said you will need to buy these separately from the valance.
If instead (or before) you want to swap the halogen reversing light globes for LEDs in your existing lights yes it is easy, I swapped mine over years ago.
Just buy a pair of P21W LED globes, plenty on eBay, then get under the car and swap them over. They sit in globe holders which undo with a 1/4 turn then you unplug the old globe and insert the new globe.
Thanks Oz,
Sorry for bothering , here's one more question I think you might know,
You just said new one that I want to go with has combined light (reverse & fog) , you are meaning there are 2 different sockets for each lamps.
Right?
Thanks Oz,
Right?
The new one has a single lens (the skinny one in your second pic) but inside are two separate LEDs.
Those LEDs are not replaceable it is a sealed unit.
you mean that If I purchase fog lights , the skinny one in my second pics, I don't need to buy the lamp seperately?
Does it plug an work to my original wire?
Yes, yes and yes.
I thought that maybe you were thinking about going to an LED reversing globe with your existing lights while you waited for the new valence and light fittings to arrive.
Hi, you should be able to get the kit from ebay. I have one sitting in my shed at home which is left over from when I converted to a quad exhaust. Here is some of the information I got when I was trying to work out what part I was getting, also dont forget the tow eye cover which is separate.
I bought my sport design diffusor on ebay,
Valience light from v8 modell, from a wrecked car.
Installation was simple, but in first place my new LEDīs would not turn off even if i turned off the car.
