DIY supercharge oil change
Haven’t done it myself yet, but t planning to do it at 50-75k miles. Shouldn’t be too hard. To get access to the fill hole, you’ll need to remove the intake crossover tube and also the SC drive belt to gain access. Make certain you use the correct (metric) Allen wrench to remove the plug, otherwise you’ll bugger up the plug. You’ll need a socket drive wrench since it’ll take a lot more than just an Allen key to break the plug loose.
Received 3,226 Likes
Coz the oil drain/fill plug is on the rear underside of the SC.
There is a post around here somewhere where Cambo put up pics of the V8 SC (Eaton TVS R1900) showing this, and the V6 SC (Eaton TVS R1320) is the same.
Not so fast there Lance, I'm 99% sure that on the F-Type an SC oil change means the SC itself must come off - right off.
And it's walkabout all one word.
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x802/blunderbuss_6929fd25ed6ed6b570bcef572a6bec7673f3adca.jpg)
I remember from my childhood watching Bugs Bunny cartoons where this was the weapon of choice for blasting turkeys.
Here is the tool for the job:
Can be used to evacuate or to fill.
SinF (08-08-2019)
I am currently attempting this on my xkr 5.l . (see my thread on the xkr section ) With the supercharged unit still in the car . The supercharged belt drive is at the front of my engine and the drain/fill plug is at the back . I was led to believe that all the 5l jaguar and RR model engines are the same . IE xf , xkr, xkr-s , x351 , and Ftype also Range rover and range rover sport all share the same engine and lay out .
George05 (08-08-2019)
That’s assuming there’s been no loss. You should put back just enough to get the level up to the bottom of the fill hole.
BugDoc
22
03-11-2021 08:47 PM
