DIY Video: Increasing Supercharger Whine with Aftermarket Intakes
Hi guys,
I made a DIY YouTube video of how to instal an intake system for our cars. It has before and after clips of the supercharger whine. Hope it helps if you are on the fence!
Link to the video;
https://www.youtube.com/watch?v=zEqG...ature=youtu.be
Link to the kit I purchased:
https://www.ywmotorsports.com/produc...8-lower-intake
Link to the video;
The following 5 users liked this post by conbrash:
djyankees31 (12-24-2019),
Luc Lapierre (12-26-2019),
OzXFR (12-24-2019),
SilverArrow2017 (01-27-2020),
Therock88 (01-06-2020)
Received 3,209 Likes
I'm normally a DIY guy but some of the installation steps in the video above look a little fiddly for someone of my limited dexterity, if you DIY please report back on how easy or difficult it is, and if you get a shop to do it please advise cost.
Also the linked ywmotorsports page says nothing at all about OS shipping.
Interested!
will do, I don’t know I might have to do some custom stuff too because I bought it for the v6 knowing they only had a v8 one available but both the systems looked similar so ill have to just try, I’ll get it done some how. The video for the v8 is definitely helpful though too, I know I saw it in the past but I prefer not to work on my actual jacks and instead have the car on jack stands so where would I jack the car up and place the jacks stands, I saw a thread before but if I recall people were fuzzy on whether or not the diagram was for a f type of xf.
I don't have any problem getting the front end of the car up in the air and safely with trolley jacks and axle stands, I have done it dozens of times.
And yes, the jacking points / axle stand points shown in the F-Type Owner's Handbook and in the Workshop Manual are dead wrong, they are XF (possibly XJ) diagrams.
The F-Type jacking points are easy to find but the axle stand points are not so obvious, first time around you need to jack the car up then look/poke around underneath to find the best axle stand points. I have found that the best axle stand points are right next to the jacking points with the axle stand snugged up as close as you can get it to the trolley jack.
justanurse (12-24-2019)
Yep, when I went onto their site just now it showed "V6 version not available". It's hard to tell if there really is only one version which fits both the V8 and V6 or there are two separate versions, I have read elsewhere that the OEM connecting tube diameters are different with the V8 being slightly wider than the V6 so if that is true there would have to be two different versions of this kit.
Unhingd (12-26-2019)
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/750x1333/9d7cc800_7044_41f4_86f4_4aa5e9c66f8f_c5cdc543547a139991dc718840fb63a6646036c7.jpeg)
Lower duct in your car
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/750x1334/a026f795_7534_4bb8_8802_e9c5e7739b5b_150526da0f272db883bdcae6b33b5cb5ce3efd60.png)
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/750x1334/14568608_2a33_49c1_82af_f97aea1a2767_d8093af7ce912fa923941645cb4e7216e71cefa7.png)
hello, thanks for sharing the DIY and the video! My question is can you post pics of the lower duct remover “the silencer” and In your opinion can it be gutted?
I just got K&N air filters which I plan to install in the next couple of days. But would like to know before hand what’s inside those two lower ducts? And if I gut them out, will I achieve the same effect with noticeable SC whine.
frostysauce (12-28-2019)
Hi,
Unfortunately it cannot be gutted, It is not like an exhaust downpipe where the inner portion is "filled" with metal. The intake silencer is hollow, but has baffles within it. The design of the intake silencer is similar motorcycle baffles/mufflers. Hope that makes sense.
Better yet have a straight tube fabricated the same size and bends with the mounting tab to replace those parts. Would it be cost effective and create the same effect (more SC noise) with free flow filters ??
yes this would work great, it would only take a piece that is a few inches long to defeat the baffle within the silencer tube. i believe this method will be the simplest compared to replacing the entire section of tubing as this tubing has a slight bend on top and has to mate perfectly with the MAS if you wanted to use the stock air box connections. That being said it wouldn't take much to replicate this section of tubing and this would provide a a better sound i think.
Hi guys,
Link to the video;
Link to the video;
I decided to make a small band to secure them and replaced one of the lower screws (which was plastic!) with a metal one and they are secure now. Some pics too for others to get a clear look at the intake with wheel apron off and my strap on the lower duct. Hope this may help others. Thanks again for posting! Excited to install them when they arrive.
DC
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1000x563/intake_shot_4e1576dba9b4a94407816999015c50fbe9492932.jpg)
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1000x854/intake_shot2_def6b94a730433b2bfd25d8b5bebbc0bc0f43c47.jpg)
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1000x778/lower1_1fa9b3db81f1c9f0875dbaa5b9577aff8be7a012.jpg)
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1000x563/strapped_2_e102d2e31fc36e4948798b46243767403b9e458d.jpg)
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1000x590/strapped_arrows_d3ecb5c388e7f75720a2601fae5cf872025f5553.jpg)
conbrash (01-06-2020)
