Does anyone know if the Eventuri intake is legit?
#61
#63
On mine the original limit was 6800 and I believe it is now 7000. Definitely needed with the MT, as I was always bouncing off the rev limiter. 6800 just isn't a sweet spot for a shift. 7k is perfect. An extra 200 rpm is not going to hurt. I'm not certain about 400.
#64
RE: dyno graphs on post #45...
isn't this the first dyno we've had published on a V6 with both pulleys swapped, VAP tune AND 200-cell cats?
I know it's sacrilegious/impossible to compare dyno graphs but... are we able to see what effect the 200-cell cats have over unhingd's setup for example? (tune, both pulleys, stock cats).
#65
#66
Interesting. sgvkirbster saw 5hp gains with this intake.
https://www.jaguarforums.com/forum/f...lation-188729/
#67
SinF (10-23-2017)
#68
Hahaha. Actually it's about 7-9 HP. But yes, point being it made way less HP than advertised. So if you're expecting anywhere near the claimed 30 HP increase, you'll be disappointed. Perhaps if u dynoed on a DynoJet or even a Mustang Dyno MAYBE (emphasis on maybe), you'll see a more significant increase. However, the increase in HP is only at peak, not throughout the range. So whatever dyno u test it on, it will only show an increase around 6,000 RPM.
#69
JagRag (10-23-2017)
#71
#73
Received 3,209 Likes
At least two other threads on increasing the F-Type SC noise, see here
https://www.jaguarforums.com/forum/f...ight=resonator
and here https://www.jaguarforums.com/forum/f...ight=resonator
Also several threads/posts on the same topic in the XF section.
To summarize, the Eaton TVS R series blower is designed to be quiet with very little "whine" and there isn't a helluva lot you can do to increase the whine enough to hear it over the exhaust.
Many have fitted after-market induction tubing kits (including me!) such as the TCP kit to their SC XFs (eg XFR) but the jury is out on whether that really increases the SC whine. I for one couldn't detect any real increase but others claim to have done so. There is no equivalent kit for the F-Type yet (the F-Type induction tubing is very different to the XF) although Mina Gallery have had one "in the pipeline" for several months.
A few XF owners have chopped off and sealed the Helmholtz resonators (L shaped protuberances) on the OEM intake tubes (3 on the XF, 2 on the F-Type) and claimed this has increased the SC whine a bit. You could try the same thing on the F-Type (see the schematic, item #9, in post #1 of the second linked thread above).
With all these XF mods I'm of the opinion that any actual or perceived increase in SC whine is really a slight increase in induction roar, as I struggle to see how modifying the intake effects SC whine.
#74
Perhaps you could figure out how to modify the symposer. Wonder if this is still installed on current cars.
https://www.jaguarforums.com/forum/f...defeat-171035/
#75
#76
#77
Modify the symposer? Disable it. See what you think. I'd forgotten how much I disliked it until you brought back memories. After I initially disabled it I bought a valve so I could manually switch it (manually, under the hood) but I never installed it because it I haven't missed it even the slightest bit. The sound is wonderful without that abomination.
#78
ltshaneclarke
10-23-2018 06:24 PM
VinnyT
03-03-2016 05:54 PM
FS[SouthEast]: 03+ STR Mina Intake w/ K&N + Mina S/C Pulley $300 shipped
larbear
02-09-2016 02:02 AM
