Does anyone know what this part is?
For those of you with a 14-17 F type before they changed the front somewhat... does this front look like yours?
After taking this picture I noticed that there's a white part which looks lower on the left side of this picture (or right of car). It's between the lower grille surround and the front splitter. Anyone know what this is? Is it supposed to look like that?
It's hard to find this but curious about yours. On most front pictures done from a height, you can't see it because of the angle...
Yes..the shiny horizontal radiator, but you should be able to see it across the entirety of that opening unless it's partially obstructed by leaves. (which happens frequently).
Thanks gentlemen. I think a part of it it may have some sort of white cover on it that makes that section more noticeable. In the following two photos I got close up, the first shows the left portion of the gap. The second on the right shows it covered by some sort of black covering. The right appears fine, however the left portion is far more noticeable. Is this how it looks on your cars guys?
I can also see it from a variety of different angles. The only angle from the front I can't is if it's from a height.
Left side close up
Right side close up
Left side close up
Right side close up
JgaXkr (04-07-2020)
