Does your driver side window go auto-up?
On my F-type R, when I press the window down button on the driver side, the window goes auto-down. When I press the up button, I have to hold it. If I let go, it stops going up. I feel like maybe it used to go up automatically too?
Having multiple vehicles, I sometimes find myself confused as to which features are on which car, which side the gas cap is on, etc... So maybe I am just totally wrong here.
Does anyone have an F-type with a driver side window that goes auto-up?
If you don't yet have an answer on configurations a bit later, I'll take a look.
Happens to me on rare occasion (not just in my Jag either). Both your driver and passenger side windows are one-touch buttons. But, as you've found, for whatever mysterious reason, the auto down/up stops working. Try this to reset the switch.
With ignition on:
--Press your driver-side button down and lower the window; Keep pressing the button in the "Down" position for 3 seconds after the window is lowered all the way.
--Then immediately pull up on the button to raise the window; Keep holding the button in the "Up" position for 3 seconds after the window is raised all the way.
That should do it. (If the window switch doesn't reset, try the procedure once again--just hold the button a tad longer in each position, say 5 seconds or so.)
With ignition on:
The following 2 users liked this post by deltagroup:
BierNut (12-19-2015),
Inspector-G (05-30-2016)
With ignition on:
With ignition on:
I have found my FTR looses its auto-up and down with some regularity, don't know why - see the dealer next week, but have to use the reset routine at least once a month.
Hold the window switch till the window goes all the way down, briefly release the switch then immediately reengage in the down direction and hold the switch for 3 seconds. Now hold the switch in the up direction till the window goes all the way up, briefly release then reengage the switch in the up direction and hold for 3 seconds. That should do it.
Truthfully, I am always forgetting whether this routine starts with the down direction, and finishes with the up direction, or if it's the other way around, so I find myself going up, then down, back up, then down again, just to be sure I've covered both possibilities.
I tried both suggested reset routines. Neither seemed to work at first, but after some additional fiddling with it, the window now works correctly. I'm not 100% sure what exact combination did the trick, but thank you for the tips!
From what you guys have said, It sounds like the problem will likely return, but at least I have a fix for it now. Thanks for the help.
BierNut (12-22-2015),
BlownBrit
12-15-2015 06:35 PM
FS[MidAtlantic]: 2004 x-type parts car
Snake9284
12-13-2015 01:27 PM
JessN16
12-13-2015 02:34 AM
