Don’t kill me but.. pops
My ‘16 R is absolutely gorgeous and is easily the most fun I’ve had in a car, ever.
BUT. While I love the aggressive exhaust, with its loud gurgling, there’s popping (like a firecracker going off) sound that happens frequently when letting off the throttle at lower speeds. I realize this may be what everyone loves.. but is there any method of reducing this? I had a friend drive the car down the street and the pops don’t sound “good” or “mean” to me.. it almost sounds like something is wrong. I just wish it was all that mean gurgle and not the pops..
Most effective way to remove any snap, crackle or pop is to buy a Prius.
Sorry, yeah, no help at all.
Carry on...I’m sure someone will chime in with a more helpful post.
P.S. On a TSB, put out years ago, Jaguar in their infinite wisdom [read as sarcasm] removed many of the snap, crackle and pops many of us here love. And the only way to regain those was to get a tune; VAP first and foremost among many of us here. So maybe, in the end, I was actually helpful?
That's definitely not the more effective way given that the snap, crackle, pops are all software related... Nonetheless, yes, I'm sure a tuner could do it. Prior to going that route though, I'd like to switch to the VAP V8 muffler, and then tune from there to remove the pops.
switching to the VAP quad exhaust on the V6 will only decrease the pops when letting off the throttle under 3000 rpm. The pops will sound like 50 caliber gunfire when letting off the gas over 3000 rpm. I can avoid the gunfire entirely by either disengaging the clutch and up shifting to avoid the 3000-3500 rpm range. The VAP is nothing more than straight pipes under all conditions unless the Loud button is turned of and only then when the Engine is under 3000rpm.
The VAP quad touring exhaust in my v6S auto develops a bit of drone at 110kph (about 70mph). It is fine at 100kph, also fine if you have it in manual and drop it back a cog. It is just that 110kph in normal mode is a sweet spot for some drone, due to the revs.
I agree with Unhingd regarding the pops, they sound like explosions sometimes. A wild and probably wrong thought is that a resonator might solve that and give a decent (but reduced) sound. I would say that the VAP quad exhaust (with tune etc) on the V6 makes it sound amazing even at idle. You would be hard pressed to pick it from a v8, as long as you can live with the extra noise which is significant, especially in dynamic. It cost me plenty to do the job but I reckon it was money well spent as the car is now everything I personally could ever want (which means I wont blow a heap more money on a used SVR) while retaining the light front end that I prefer about the 6.
On a slightly related matter, and in case many did not see this (with apologies to the OP for the diversion):
Of course, this one is even better (and I think I’ve watched it many 50 times; and in case you where wondering, “where did our very own Unhingd get his name from?”)
BruceTheQuail (10-18-2019)
Recently, i have been playing with a few different setups, on the 6cyl the drone is coming from the resonator on the mid pipes, if you put a v8 midpipe on a v6 it looses the drone but gets much louder, if you put a V6 midpipe on a V8 it also gets a drone at 70+-. 100% it is possible to cut out majority if not all of the pops with a tune, its just a fuel dump. i also believe the "gargling" noise is the supercharger bypass valve causing turbulence in the intake when you let off, heard a few roots superchargers make this noise. The valves in both the stock and VAP exhaust can be set to open/close whenever you would like them to again with a tune.
