Door Handles for Closing?
Old 10-15-2021, 07:30 AM
davidmaria1's Avatar
Default Door Handles for Closing?
This might sound like an amateur question. When the drivers door is open and I go to close it, any pressure on the handle causes 2 quick beeps from the horn.
Do I have to touch the door or glass to close it? Disclaimer: Decades ago I was chastised by a Benz factory rep for not using the handle on a 560SEL for closing.
Old 10-15-2021, 08:13 AM
scm's Avatar
scm
scm is online now
Received 1,481 Likes on 1,121 Posts
Use the door, not the glass or the handle to close it.
Old 10-15-2021, 08:26 AM
[QUOTE=scm;2453689]Use the door, not the glass or the handle to close it.[/QUOTEThat's what I thought.
Good thing I got another black car!
Old 10-15-2021, 11:39 AM
jlewis10's Avatar
That "feature" drove me bonkers, especially when working on/around the car with the doors closed, any time I would lean over and bump a handle, BEEPBEEP. Loud AF, too.
I disconnected that little horn entirely, and am much happier. It's separate from the HORN horns, it's just a little alarm horn tucked down under the hood by the firewall.
Old 10-15-2021, 11:41 AM
eeeeek's Avatar
I use the trim at the top of the door, below the glass.
Passengers usually use the handle, freak out when it beeps, and then use either the door, getting fingerprints all over it, or the glass, which makes me sad. It would have been nice for there to be some sor t of designated space with a little flat paint or something integrated into the design.
Old 10-15-2021, 12:07 PM
scm's Avatar
scm
scm is online now
Originally Posted by eeeeek
Passengers usually use the handle, freak out when it beeps, and then use either the door, getting fingerprints all over it ...
You don't make your passengers wear cotton gloves?
The following 2 users liked this post by scm:
Carbuff2 (10-15-2021), Spyderturbo007 (10-28-2021)
Old 10-15-2021, 12:16 PM
SouthSider's Avatar
[QUOTE=eeeeek;2453772]I use the trim at the top of the door, below the glass.
Same here, keeps the smudges and prints off the glass and paint.
Old 10-15-2021, 01:06 PM
sov211's Avatar
Received 2,261 Likes on 1,366 Posts
[QUOTE=SouthSider;2453783]
And I do the same - it's easy.
Old 10-15-2021, 01:43 PM
KalamazooJag's Avatar
This same function happens with my XJL. The exterior locking button is located in the center of the handle and everybody thinks they need to push it to open the door. Still makes me jump and I know they are going to do it every time...LOL.
I use that trim piece under my F-Type glass as well. The funny thing is that sometimes, even when I have my key, when I TRY to use the door handle to LOCK and ARM the car, it will fold in, the beep and pop back out.
Old 10-15-2021, 02:28 PM
FeralSVR's Avatar
Look at the thick rubber weather seal attached to the backside of each door. At the top You will notice a large circular indentation in the rubber strip that is about the size of a quarter and large enough for one or two fingers. I use this method to close my doors from the outside. Just a little "tug" does the trick. First timer passengers seem to pick up the routine fairly quickly when shown this little convenience...
No fingerprints and NO BEEP!
Portlander (10-15-2021)
Old 10-15-2021, 03:11 PM
This sounds like a good idea. I can tell you my wife is not interested in having special methods for closing a door. The horn is also part of the security system? Maybe we'll try it.
Old 10-15-2021, 03:20 PM
eeeeek's Avatar
I am so changing that horn to one that plays 'God Save the Queen'.
Old 10-15-2021, 03:35 PM
Fireze22's Avatar
Surprised nobody has mentioned using these:
https://www.jamhandle.com/
Old 10-15-2021, 05:45 PM
SS4PK's Avatar
Haha, same here.
Old 10-15-2021, 05:48 PM
SS4PK's Avatar
I agree instructing my wife on how to get in my car is not received well.
Old 10-16-2021, 12:45 AM
Cgo's Avatar
Cgo
Cgo is offline
those are brilliant. Getting some asap!
Fireze22 (10-16-2021)
Old 10-16-2021, 03:20 AM
takeapieandrun's Avatar
Changing the loud beep for a small piezo speaker was one of the nicer QOL mods I made.
Old 10-16-2021, 08:06 AM
Dwight Frye's Avatar
The only time I have had the beep alarm go off from touching the button on the handle or accidentally pushing on one of the handles on the door that is popped out is when I don't have the fob on my person.
It seems that there is no way to lock the doors if you don't have the fob other than through the InControl App of course.
Old 10-16-2021, 10:54 AM
Thunder Dump's Avatar
If you don't have the fob on you, you can still lock it by pressing the lock button on the *inside* of the door and then closing the door.
Old 10-17-2021, 09:19 AM
Thanks I'll try that. My usual practice with cars that have electric door locks and fobs for locking/unlocking has been when the engine is off and the door is open, press the lock button on the interior door panel, get out and swing the door closed. That way the fob never leaves my pocket, the door is locked and to unlock I just press the button on the exterior handle. I dislike having to give the handle a bump to lock the door after exiting the vehicle. I get a feeling that mechanism is something that will eventually fail necessitating an expensive repair.
Quick Reply: Door Handles for Closing?
