Doors will not lock
Doors will not lock
So the latest random event on my 2021 P380 vert is that it will not lock.
Any ideas before I try to arrange a dealer visit and wait 6 weeks?
I am getting a bit pissed off with the random electronic behaviour.
Seems like every other week things do not work then come back the next day,
Not convinced the locks are in that category.
Ithought the era of Lucas electronics was over!!
I have a 2000 mile trip planned but am geting nervouse about using the Jag
Hard to deal with the irratic situation on a $100K vehicle.
I hesitate to respond, since it appears you've never found anything you found useful on the forum.
This can be an easy fix or could require one of a couple of parts.
Will the car not lock when you're driving or just when you're leaving it?
Does it not lock when you use the FOB as well as when you lock it manually by pressing on the handle?
Are you getting a little double beep when you try to lock it manually and the handle pops back out?
And, are you sure you don't have the second FOB around so that the car thinks you might be locking the key inside?
I have no idea why you are saying that I've never found anything useful.
Just the opposite!
And I have never indicated otherwise.
Yes, double beep and handle pops out.
And no, it happened first while 10 miles away from my second FOB
Just the opposite!
JABB (05-24-2024)
FYI, Jaguar basically stopped using Lucas "the Prince of Darkness" "the reason English people prefer warm beer because Lucas makes refrigerators" & "the inventors of the 3 position headlight switch-dim, flicker & off" since the X300 was launched in the fall of 1994. So you can't blame Lucas.
It starts to feel a bit like a Twitter or Facebook contest for who gets the most "likes".
I appreciate all responses I get on this and 2 other F-Type forums I belong to.
I quite often try to contribute to help others.
I sometimes thank those who have helped me.
Enough said!!
Regarding the original reason for my posting, the problem is solved.
It turned out that the trunk was not completeely latched.
This is weird because just prior to the problem becoming apparent, the doors had locked normally, and the trunk had not been opened after that.
There was no indication on the dash and it certainly looked closed.
I had checked the vert roof closure few times, just never thought to check the trunk, which is a manual close on the vert.
So, I only feel a little stupid!! Perhaps this post will help some body else??
Enough said!!
I've been told the reason is mostly German logic....German engineers assume an open trunk/boot on a stationary vehicle is an intentional act (you opened it so you could put something in/take something out) and therefore does not need a warning and they don't want to bother the driver with unnecessary warnings that are not germane to the operation of the vehicle. Only if its open when the vehicle is moving is it an alert-worthy event. Many European manufacturers, such as JLR, adopted this logic as well.
Personally, I'd rather have the alert whenever the trunk/boot is ajar and let me decide how concerned I need to be about it, as it is far more convenient to fix the problem at rest than once you start moving when it's not intentional.
The trunk on the convertible is manual close. I must admit to not wanting to"slam" it doen but it certainly seemed closed and the car clearly thought so as well for a while.
I had driven the car a few times since last opening/closing the trunk nad had locked it normlly at least once before the problem occurred.
I would guess this is a vert-specific issue.
Correct--mine is as well. With the car running and in park, pop the trunk with the button on the dash. You'll hear it release but won't get any warnings of any type on the dash. Now put the car in gear and move forward--you'll get an alert on the dash. The circuit is monitored even though it's a manual close (via the interior trunk lights that come on when the lid is popped).
Since the solution turned out to be, in fact, the most obvious cause of not locking (that is that one of the latches was registering a non-closed position) can someone add a SOLVED to the title? There was no defect in the car. Leaving the thread headings of this sort without an indication that the problem has be resolved gives the impression that these cars are rife with problems. In fact, very often the problem lies with the owner, not the car.
For some reason, the European manufacturers usually only display a trunk/boot/tailgate/liftgate ajar warning message on the dashboard once the vehicle is in motion (i.e. vehicle is put in any gear), unlike US/Japanese manufacturers that display the warning instantly once the circuit is open. BMWs are famous for this. When I had my E93, on more than one occasion I would start moving forward only to have the trunk ajar notice come on and have to pull over and secure it.
My best guess is that the trunk was latched enough to avoid the sensor indicating it to be open.
I was able to lock the doors then I was unable, even though I had not open/closed the trunk.
I agree with you abou the in control app - just did not realize the what the problem was causing the doors to not lock.
Enough said!!
Enough said!!
CJSJAG, thnx for your post. I have same prblm with my 2021 FTR Coupe so I thought I found a solution in your solution but it was not to be. Trunk, doors and hood are all slammed tight but the car cannot be locked. If any readers have any good suggestions plse fire away. Note that ALL basics have been covered - e.g. no conflicting FOBs, FOB batts 100%, etc.
The locking function worked beautifully until I recently took it to my dealer for another problem.
Thank you.
Thank you.
Thank you.
If it's the former, the app should tell you something. If it's both, you'll see a message on the screen. It doesn't have to actually be an issue with something not closing properly; it can also be a sensor error. That was the issue in my case.
