Downshift in manual (paddles) mode
Hi all, so dynamic mode on, lever to the left for sport shift, car still downshift automatically when you push it to the floor. Have done a bit of reading and appears this is how it is designed to behave, but it is slightly annoying to me. If I choose to be in full manual mode, I want to be in full control, instead of pressing the pedal and suddenly the car downshifts and lurches forward. Any way to disable this?
yup sport mode enabled, still will downshift - if I'm cruising at 3000 rpm in 4th and floor it, it downshifts to 3rd even when s and dynamic are engaged. BTW this is a 2015 R, not sure if different years behave differently.
OK, so, you want to stomp it, but not really maximize acceleration. You'd probably come closer in Drive vs Sport, and not punch it so hard, since Sport thinks you actually want to be aggressive. Do you also want it to stay in 4th when you pull up to the next stop light, forcing you to be truly manual?
Yes, there’s a kickdown switch on the throttle pedal - I think you can feel it when it’s almost to the floor. If you hit that, I think it pretty much overrides everything. Don’t know if a tune could disable it. If it’s a mechanical switch, perhaps it could be disconnected. But I suspect it’s electronic.
Depending on how you configure it, you can get manual mode in D, too, although that will revert to auto if you don't touch the paddles for a while. In S you can also use the stick to shift - forward to shift down, back to shift up.
Cluck (06-04-2022)
If you built a little doughnut/block on the floorboard, you could probably block the kick-down switch. Of course, it will ALWAYS block the switch, so you'd have to rely on the paddles/gear shift to do any urgent downshifts. But, I think that fits what you said. Just a thought.
I, personally, wouldn't be tempted to restrict the car, but I recognize you're dealing with the maximum horsepower / RWD combination, so sudden downshifts under power can get interesting. (In my V6-S, it's just part of the fun.)
They day I picked up my car from the dealer I was about a block away and had to make a U turn at a traffic light from the left turn lane. As I was doing so I accidentally lit the paddle and downshifted and then when I completed the turn and started to accelerate it took a few seconds to figure out why the car didn't automatically shift gears.
When I got home I programmed the settings so that the paddles would only operate when I moved the gearshift lever to the left to put it in the sport mode. That makes the most sense for me and after driving the car for a while like that it became almost second nature to put the car in Dynamic mode and move the lever to Sport when I wanted to drive the car in a spirited mode.
lunagry
09-24-2014 12:50 PM
guestlinger
08-14-2012 09:06 AM
