Driver's Side Engine Compartment Fuse Box
I had the same problem when my seat heaters were blowing fuses. The way I figured it out was by finding the only fuse with a specific amp rating. Once you find that (use the seat heater fuse) you should be able to work out the rest. The box is actually labeled but it is almost impossible to read.
