DRL dim on one side
DRL dim on one side
I got a 2019 F Type R and the DRL on the driver side is significantly dimmer than the passenger side. The service advisor said that jaguar won't let them replace it as long as the light itself is working, even though it's not working as intended. Curious to see if any others have has this issue with their DRL? Thanks!
Have not had that issue. Mine are both consistently bright. No issues. I do not think it makes sense to not replace if it is not completely burned out?? That is just dumb. So if the car is accelerating, but sputters, it is still "running" so no issues right??
If the wheels roll, but wobble, they still roll...right? So if the lights were intended to light up at 5300K or 6000K, but they are dimmer...They are NOT functioning as intended!
If they want to play games like that, maybe pull the wiring diagram and put a surge through it to burn it all the way out...Then they are NOT working as intended
DC
DC
DC
DC
Experienced this issue with a 2018, it wasn't dramatic, but one of those things I couldn't un-see after seeing it.
Dealer agreed to take care of it without too much fuss. Replacement headlight has been on order for about 3 months now though.
I'd press the dealer to make the replacement as the MSRP on the headlights is ~4K.
KimboSlice (05-22-2023)
If you're being serious, I'm very jealous right now. I miss those days... Probably seems crazy to you while you're in it, but when it's gone...you miss it.
bklynchris
06-26-2014 09:27 AM
