Dropped!
Old 03-02-2016, 10:23 AM
sanarchy's Avatar
Default Dropped!
So I got it all done, with thanks to many of you here. H&R lowering springs, Motorsport Tech spacers and MGP caliper covers. I absolutely love how it looks!
Old 03-02-2016, 10:33 AM
WhiteTardis's Avatar
I'm not going to lie...that drop along with the spacers looks really good..but H&Rs drop is too aggressive for OC and LA roads. Be ready to chew through tires though, that drop is too aggressive to get the car's alignment back or close to spec.
Old 03-02-2016, 10:36 AM
Kief's Avatar
Perfect!
I wish the wifey would raise my allowance so I could add some goodies
Just purchased a second set of wheels for my "winter" needs and she's ready to cut me off
Old 03-02-2016, 11:37 AM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
Just how bad are those roads? I can't imagine your ruts and potholes are any worse than here in the Baltimore/DC area.
The front camber can just barely be brought back into spec and the rear camber (not adjustable) will fall just slightly out of spec (but is actually a better track spec).
Old 03-02-2016, 11:51 AM
Foosh's Avatar
Received 1,028 Likes on 854 Posts
They're not, actually roads are in much better shape than here, but in the surrounding canyons and hills, there are a lot of steep grades.
I also think it's only a matter of time before you pay the price. There's no way I'd run an F-Type dropped as much as you guys did around here.
Old 03-02-2016, 12:22 PM
sanarchy's Avatar
what price am i going to pay?
Old 03-02-2016, 12:29 PM
Unhingd's Avatar
Yep...gotta be willing to pay to play. No use fretting over it. (and the car hasn't caught fire yet, either)
Old 03-02-2016, 12:54 PM
hardwired's Avatar
More pics please. Close ups if you will...
Ninja edit: especially the caliper covers
Old 03-02-2016, 01:22 PM
Jaronstoys's Avatar
How do the covers fit and look? And what model number did you use? Looks great !!
Old 03-02-2016, 06:31 PM
sanarchy's Avatar
The covers are okay - not perfect but they sure look better than the stock calipers...
MGP® - Jaguar XK-Type 2014 Caliper Covers with Jaguar / Leaper Logo Engraving
Old 03-02-2016, 06:32 PM
sanarchy's Avatar
Old 03-02-2016, 06:35 PM
lsbrodsky's Avatar
Not a fan of caliper covers, especially on a car this nice....
Larry
Old 03-02-2016, 06:37 PM
Jaronstoys's Avatar
Cool thanks !!
Old 03-02-2016, 07:03 PM
ShaunPA's Avatar
Larry
Stance looks great.
I agree on the caliper covers.
Old 03-02-2016, 07:40 PM
Unhingd's Avatar
I concur. I think you'd be happier with a can of high temp red or yellow spray paint.
Old 03-03-2016, 01:17 AM
bjg625's Avatar
I agree, get them painted! Stance is great hope it still drives nice.
Old 03-03-2016, 06:09 AM
Kief's Avatar
Not that you asked any of us to give our opinions of your caliper covers, but yes, please take them off! A cheap and easy spray will look so much better IMO.
The rest of the car looks too good to now have those covers take away from the overall look.
Old 03-03-2016, 06:28 AM
mshedden's Avatar
I'm surprised y'all will run with a 'cosmetic' drop that will put the camber out of spec, esp given the cost of tires for these cars.
Adjustable upper arms are usually the solution, but I would think in this case a good fix would be some (drilled for the bolts) aluminum bar stock of a calculated thickness between the body of the car and the suspension members to push things back out to where they belong? Cheap fix I'd think.
Old 03-03-2016, 07:43 AM
Unhingd's Avatar
On all my other cars, I spent good money on eccentric bushings to get more camber than otherwise available. It improves handling (yes, at the expense of tire wear). My decision to drop the car is far more for the handling (better camber and lower center) than for the esthetics. At a lateral 1g, roll torque is reduced by about 440 ft-lbs with the H&Rs.
Old 03-03-2016, 08:22 PM
Rochester's Avatar
Fitment looks absolutely fantastic in that pic. I think it's beautiful.
Sometimes being too concerned about having camber "in-spec" can be over-thinking things. A little extra negative camber often has no impact on tire wear, particularly if you're using high performance tires with a limited life. As long as toe is lined up properly, you'll be fine.
MGP Caliper covers are no bueno, IMO. It's a tacky mod on an otherwise classy car.
Foosh (03-03-2016)
Quick Reply: Dropped!
