Dual pulleys - tune - pushed hard on street - some codes?
Finally got a check engine light after 300+ miles when pushing it hard on the street. The codes are as follows:
P0304 - Misfire Detected in #4 Cylinder
P1315 - Persistent misfire (one cylinder identified and injector switched off)
P2169 - Exhaust Pressure Regulator Vent Solenoid Control Circuit/Open
U0447 - Invalid Data Received From Gateway 'A'
U0010 - MEDIUM SPEED CAN COMMUNICATION BUS
Im assuming the U codes are from the tune, and no big deal. Any ideas from the forum gurus before I start throwin some parts at her? Thanks guys!
Don1954 (05-31-2018)
Ok, I replaced the coils on cylinder 3 and 4 with OEM Jaguar units. Took it back out. At super high RPM on the highway, its still misfiring on 3 and 4, and now says cylinder 1 as well. As soon as I pull over and restart, its fine. Is it related to a tune issue, or maybe module or control board? Seems like a resistor is bad, or the control module voltage may be screwing it up.
John Jones (07-14-2018)
Any update on this? I've installed the crank pulley with the stock V8 spark plugs (my guess is that they are 44k miles old) and am getting misfires with the car going into limp mode (Restricted Performance mode, no CEL though).
Am wondering if its the spark plugs or any other issue. Will try and replace the spark plugs in the next couple of days.
Whoops, should have mentioned, I have the crank pulley, Eventuri intake, 200 cell cats, according VAP tune and Aquamist water injection system.
Edit: also seem to persistently have an "air flow too high" code stored in the ECU. Not sure if it's improper installation of the Eventuri intake or an air leak in the Aquamist system
It was indeed the VAP tune. Too much timing uptop. Got with stuart and chris, and chris had me a new tune in a day or two. Pulled a few degrees of timing from up top, as it was pushing the stock coil packs too hard, and then shutting down the fuel injector, which is causing your limp mode. I replaced ALL my coils with brand new OEM limits, but it made no difference.
When I take it to the dyno, I will log it to see the absolute max we can push a V8 w/ no cats & dual pulleys. If you havnt changed the plugs for the additional boost, you absolutely should.
ss23 (07-14-2018)
I'm really interested to see your logs and how much power you can make out of the V8! What mods do you have barring the dual pullies and tune?
