Dynamic mode
powerhouse (04-24-2018)
yea Bruce bit different than the xkr, it was just to clarify that i can as lizzardo said, i can switch on the dynamic mode while driving. On the sport mode point, can you switch it over on the move too and what's the difference in you choose Sport and dynamic.
You can switch off the paddles after using them - don't recall if you hold in both both paddles, or just the right one.
I have mine configured so they aren't active in dynamic, only dynamic+sport. Probably active in sport only too, but I never use that. Can be configured in the menu via the steering wheel buttons.
![Icon Omg](https://www.jaguarforums.com/forum/images/smilies/icon_omg.gif)
In the Dynamic config, everything is "On" (Throttle, Exhaust, Suspension).
I'll leave everything normal for highway driving.
Sport Mode is when you're feeling frisky and/or on a 2-lane.
I have the paddles enabled in both modes (although my wife's car has them set only for Sport).
To expand on the posts above, when you use the paddles in regular Drive mode, the transmission will revert to automatic if you're drive along a bit at a steady pace. In Sport mode, the paddles stay active. In both modes, holding the right (+) paddle for a few seconds will take it back to automatic.
Since I rarely put the top up, however on long highway runs I will put it in what my wife refers to as gentleman mode; to soften the noise.
PBBarb (04-25-2018)
So seems a lot of people drive around in dynamic mode, so what's the best settings to get the most from it. What's the best way to go in the settings. Usually i just have it in D while cruising, with dynamic off, haven't used in any other configuration. I just use the paddles from time to time on slow driving, like through a town or village, more noise
any input welcome. My older xkr had none of this trickery.
Don't even know if it has The Configurable Dynamics system, it may have been an option, if it hasn't this what's the setup then.
![Icon Steer](https://www.jaguarforums.com/forum/images/smilies/icon_steer.gif)
powerhouse (04-25-2018)
I use dynamic, except:
1. On long highway cruises. Non-dynamic has lighter steering and throttle response, which is less fatiguing. Also, mileage is slightly better, for those who care.
2. On bad pavement; dampers are a bit softer. I suspect you don't have active dampers, so this wouldn't apply.
3. If temperatures are really cold, as summer tires don't have much traction at cold temps. Then again, I don't drive it much when it's cold out.
If I'm somewhere I can drive aggressively, I throw it in Dynamic+Sport and use the paddles. Or for more noise.
If it has configurable dynamics, it should show up on the screen oin the next window after the home screen (i.e. where the valet stuff etc is).
Mine has the adaptive suspension which goes harder when dynamic is engaged, but it isnt configurable. So essentially if I want to drive in dynamic, it is quite a hard ride, which I dont like.
So first check your main screen and see if there is an adaptive dynamics tile when you go to the second page. If there is, then you are in business. If there isnt, change into dynamic on a second grade road when you are on the move at say 60kph and see if there is a noticeable change in the ride. If there isnt, you probably dont have adaptive suspension so only the steering weight and throttle response (and exhaust) will change when you engage dynamic - I'm not sure about transmission.
Personally I like the transmission when it is in sport. Holds gears much longer, really good for twisty roads.
Have seen where some people pulled fuse 15 in the engine bay left hand fuse box where the F-Type 3.0 S active exhaust not fitted, no factory switch,it leaves the AE valves open, No problems and an ideal solution for those that don't have the factory switch. So no apparent problems, no warning messages is this the case, anyone done it.
ahost
XE ( X760 )
21
01-15-2020 04:21 PM
